Post your Solid State pics here.
Old 16th February 2018, 06:48 AM   #5641
borys is offline borys  Ireland
borys's Avatar
pinnocchio
Irish steady hands technique is good until the bottle/PCB ratio is bellow 1:10 at about 1:1 it makes opposite what it ment to do
Received missing parts for MiniPSU, soldered them, powered UP, no fire, no smoke --> happy.
Have made some YT video too:
YouTube
Mile
Nice build but for some reason I do not like the cables all over the chassis + signal wiring/ribbon going around/under the transformer.
For prototype build it is very easy to use 1,5/2,5mm^2 solid core wire, just cut, align and solder, no meas at all.
Peter
-->> i-AMP <<--
Old 17th February 2018, 02:36 PM   #5642
Lensyc is offline Lensyc  Russian Federation
le class
Old 17th February 2018, 02:47 PM   #5643
le monstre
Old 17th February 2018, 05:22 PM   #5644
kct is offline kct  Canada
kct's Avatar
^^^ very nice.
Old 18th February 2018, 02:27 PM   #5645
HH is offline HH  Europe
Some months ago, I built Fabs USSA-5 class A amplifier on a very nice black PCB designed by Project16 and Alex.
The USSA-5 turned out to be an excellent amplifier that do most things very well, but what specifically impressed me, was the smooth and detailed highs and the big soundstage. I was curious about the other USSA iterations, and several members from diyaudio.com recommended the USSA-3, which is a simpler design than the USSA-5.
The USSA-5 PCB can be used for USSA-3 amplifier, and Fab has produced an excellent building manual, that walks you safely through the build. I finished my USSA-3 about a month ago, so I have had a good long listen before posting my impressions. I have compared the sound of my USSA-3 to the USSA-5 and Bonsais SX-Ovation.
I am running all my amplifiers on completely identical power supplies, so the differences I am experiencing can only be ascribed to the circuit design and my choice of components.
The USSA-3 has a very full and natural sound. All well recorded acoustic instruments will be reproduced in a very realistic way – almost tube like. Where solid state amplification excels in dynamics and detail, they often have a sort of hidden "whitish" glare that is – more often than not - less natural sounding than what a good tube amplifier can do. Many good solid-state designs are somewhat tilted towards a bright sound reproduction, that highlights details and recording artefacts like studio walls and such. I think, too many audiophiles are focusing more on details and soundstage when choosing their system, instead of asking themselves the important questions: "Can this system really reproduce the nylon strings on a Spanish guitar? Can it reproduce the left side of a Steinway grand piano in a way that energize the room? Does this system reproduce the warm bloom of a bass solo on jazz recording?" The USSA-3 do ALL these things more convincing than the other amplifiers I have built (that includes several Pass First Watt amplifiers)
During the last couple of months, I have been swapping between my USSA-5 and my SX-Ovation, having a tough time deciding on which amplifier I preferred. Where the USSA-5 excelled on finesse and detail, the SX-Ovation was a bit more dynamic with better lows, but some rough edges here and there. Somehow the USSA-3, with its simpler input stage and smaller amount of feedback, comes across as the more musical of the three designs.
The highs of the USSA-3 are pleasing and smooth and the bass is mighty fine too. The bass has a ”looser” quality than the USSA-5 due to a lower damping factor but is somewhat similar to the full BJT bass of the SX-Ovation. When listening to the USSA-3 you stop focusing on all the audiophile artefacts of a good recording, and just enjoy the wonderful sounds flowing towards you from your loudspeaker. The sound is big and very much full-range.
I can only recommend that all fans of the USSA-5 also build the USSA-3. I am pretty sure that you will be pleased and surprised. I want to thank Fab for sharing this design, and as always, his building instructions are second to none.
There has already been several group buys for the USSA-5 PCB on the Quebec DIY audio forum, and I am sure Fab will do another run of PCB’s if the demand is there – and it really should be. Buy the PCB – and go build yourself an USSA-3 or an USSA-5. Both designs will reward you in the most impressive way, but for me in my current setup the USSA-3 is the preferred option
Old 18th February 2018, 02:29 PM   #5646
diyralf is offline diyralf
diyralf's Avatar
I wouldn't use FET in audio circuits. Their linearity is not so good.
Old 18th February 2018, 02:47 PM   #5647
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Having build both versions of the USSA you are talking about (plus a couple more before that), I can only agree with you. At the moment, the USSA 5 is my main amplifier, the USSA 3 is fully assembled but just missing the final chassis which I'm working on.
You seem to be enjoying the amp which makes me very happy for you and Fab. He gave so much time and attention to detail for these amplifiers, gave detailed instruction manual and lots of help on the French forum. Everyone should try these amps.
Here's my version of the USSA 5
Amplificateur USSA: Dans le ventre de la bete - construction par Pinnocchio - Page 7
Do
PREAMPs : AMB α10 + USSPA | LDR3x + USSPA | AMPs: AMB β24 | USSA5 | TGM8 | VZ Audio NS OPS | FC-100 | Modulus-686 |
DACs : Mirand AK4490 + Discrete Output | Ian Dual ES9038K2M | Speakers : Troels Gravesen ATS-4 | Sagwee LT V3 |
Old 18th February 2018, 03:18 PM   #5648
Hello Do,
It was your praise of the USSA-5 that originally sparked my interest. You had built and listened to so many well-known amplifiers, and the fact that you preferred the USSA-5 made me curious.
I attached a photo of my final build of the USSA-3.
I totally agree with you, everybody should try these amplifiers.
Old 27th February 2018, 12:38 PM   #5649
Luke is offline Luke  New Zealand
Send a message via AIM to Luke
Originally Posted by HH View Post
Hello Do,
Are pcbs available for these amplifiers?
If you give a man a fish he will eat for a day. But if you teach a man to fish he will buy an ugly hat. And if you talk about fish to a starving man then you are a consultant. Dilbert
Old 27th February 2018, 02:07 PM   #5650
pinnocchio's Avatar
Hi Luke,
I might have an extra set. Please contact me by PM
Do
Post your Solid State pics here.Hide this!Advertise here!
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
