There are a number of versions of this (confusing).
How about this one? Also, in place of the THAT 340 you can use JFETs (J74/K170).
There are only 2 x LEDs on this PCB.
I think this might be what you need? The Multi Amp aka Dynalo Mk2 - Page 51 - Do It Yourself - www.Head-Case.org
The middle pin of the TO92 is not the base. CBE is common, BCE too, BEC and CEB more rare but seen.The lower LED appears not to be biased? I've checked my work and that is how that transistor is connected.
In this setup the led is connected to the emitter the 10k-100R node is on the base.
- Kevin Gilmore
