F6 build
F6 build
Thread Tools
Old Today, 03:41 PM   #31
intojazz is online now intojazz  United States
Hey,
Iíve received most of the parts to begin the build already. I ordered a transformer from Antek and have been reviewing the bom for the power supply. The recommended electrolytic caps are 10000-15000 uf 35v. If the caps are in that range and fit the pcb properly nothing else changes, right? Iím asking because I see where larger value caps have been used (18000 uf). Just want to be sure before ordering.
Old Today, 04:02 PM   #32
Bikeratl is offline Bikeratl  United States
Thank you @ColinA123 and @TungstenAudio for that info. I noticed my kit from diyaudio included 8 zeners, and although the markings on 4 indicated 5.1v but the other markings didn't show up in a digikey search. Once I looked at the old BOM they were indeed 6.0v, so I'm all set there. Unfortunately I had soldered the 10kOhm resisters into R7and R8 before I saw that, so I'll desolder that and order the 3k3 for those spaces. Glad I bought that solder sucker.
@intojazz - You are a step ahead of me, but I was just looking at transformers yesterday and was wondering that myself. I also ordered the softstart board and the DC protection board as well, so I have to look thru those and order those parts as well.
Old Today, 10:35 PM   #33
ItsAllInMyHead is offline ItsAllInMyHead  United States
F6 build
Originally Posted by intojazz View Post
Hey,
It is completely your choice re: caps. Make sure your choice of diameter and mounting parameters (snap-in) match the board. You'll see a zillion opinions.
One opinion...
If you have an inclination that you may want to do a higher power amplifier in the future using the same power supply... you might choose to get 50V rated caps. They are not that much more expensive, and will allow a bit more "future proofing". If you know that this PSU will only be used (conservatively) below 30V or so... then 35V caps are just great. All First Watt amps are ~24V rails.
Common choices are 35 or 50V rated 18kuF or 22kuF. If you can find 105 degree rated at a price you're willing to pay, they might last longer. If not... just get 85 degree rated caps and don't lose a wink of sleep.
If you want a friend, feed any animal - Perry Farrell
  Reply to this post
F6 buildHide this!Advertise here!
Thread Tools
First Multi-way Build. What to build for a big room? chirs Multi-Way 12 4th December 2013 03:53 AM
First Open Baffle Build- Build is done harvylogan Multi-Way 11 17th December 2012 02:15 PM
Build or not to build - $300-500 budget sasav Multi-Way 19 6th January 2012 02:27 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 07:54 AM
Do i need to build main supply (240v) filter?Or build power distribution? thomgun_lc Chip Amps 9 16th September 2005 09:52 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
