25W Single Ended Hammond 193V Choke Loaded 2SK180 L'Amp
Thanks again for this information Ben.
https://www.diyaudio.com/forums/pas...-choke-loaded-2sk180-lamp-21.html#post6631726
I'm starting to gather parts for this build and have been checking out suitable chokes - I have found the Lundahl LL1694 filament choke, a smaller brother to the LL2733 - connected with its windings in parallel the LL1694 is rated at 0.04mH 3A so looks suitable for my project to build a bandwidth limited version for the main driver in my Pass SLOB speaker build as it will further roll-off the bottom end. Is my thinking right on that?
https://www.lundahltransformers.com/wp-content/uploads/datasheets/1694.pdf
Cheers
Your thinking is right but your numbers are wrong. Starting with the choke which is 0.04H.
40mH will move slightly the low frequency limit but it still remains below 10Hz. Remember, the source has a really low impedance so the choke even at 40mH @10Hz remains a much bigger load.
If you need some meaningful filtration choose a much lower value, a 2mH speaker inductor will get you in the region of 100Hz.
nautibuoy, that choke should work in the amp but as analog_sa mentioned, it will not shift the low frequency point by a significant amount. However you can further adjust that by lowering the input coupling capacitor value to suit your speaker.
Yes, I probably didn't phrase that very well. What I was trying to say is that rolling-off the bottom end by changing the input cap, as per the simulations, lessens the demands on the choke so I can use a lower value one, at significantly lower cost, and it will have a small benefit to the roll-off. The choke isn't intended to be the primary means of rolling off the bottom end.
I also looked at the Triad C56-U choke, specified as 0.035mH, which would have a similar affect but is only rated for 2A. Though it's about four times the cost of the Triad, the Lundahl's 3A rating gives a lot more flexibility when evaluating the optimal operating point.
I think I'll buy an LL1694 and assemble, test and measure one channel with my full-range drivers mounted on a representative baffle.
Although building a bandwidth-limited buffer for a very specific use-case might seem a bit constraining, a great advantage of these designs is there simplicty and low-parts count so it will be pretty simple to revert it to full bandwidth operation, especially with a bit of forward planning.
Ray
Your link is for TO3 spacers and none of the Tokins are TO3. Chances of finding suitable ceramics are slim. Keratherm is easily available and can fit any footprint.
what about having two 5x5 spacers , with a space beteen the two for pins (with the 2SK180/2): then there is only need for one hole per sheet to be made. Still need a ceramic drill but these are available.
Hello,
my inductors are 0.1mH 5A, which is in your opinion a safe and low distortion working point with the THF51?24V or 36V psu? I don't need more than 15W and I've 6 and 8ohm speakers
I'll drive with AKSA Lander.
Guglilemo
In my sims, the 40 mH is giving a Fc of some 17 Hz. Not bad.
But looking at the LL1694 I see that in series it is 16 mH. that starts to be bad bad.
But the LL LL2733: that is a clear winner, giving 8 Hz. Two coils parallel 100 mH, and you can use it as a grill with 3.4 Amp😱
albert
Hello,
Guglilemo
Nice choke. Where can that be found? I am asking some Alie's shops for 100mH-150mH/2-3Amp = something like this; no response yet.
& And in my sim with 2SK182, @ 4Vpp in, with 24V/2.1 amp = -36dB 2nd /-55 dB 3rd while 39V/2.5A = -45 db / -67 dB. So higher Vb is better, then the 2SK182 becomes more lineair.
Compare to the 2SK180 at 24V -31db / -41 dB @ 4Vpp that also has many more higher harmonics. But they still have a nice degradation [on paper that is] 🙄
Only Papa knows what is better from paper.
Hello,
my chokes are from Italy, Megahertz was a small company of the past. I want to try my Thf51 follower in the next days.
Do you have any suggestion of the sweet spot for THF51?
I've bought isolator kits for THF51 from pras1170 if someone is interested.
Regard
Guglielmo
I suggest a Vds of 35V and Iq of 2.5A. Depending on the DCR of your choke, the supply voltage would be 35V + (choke DCR)x2.5A. If you have lab power supply you can play around with the voltage and current and measure the distortion.
Because it is a follower, you will need a preamp or voltage gain stage that can output a lot of voltage if you want to test the amp at high power output. The measured distortion then would be the combination of the distortions of the preamp or voltage gain stage and follower amplifier.
