Tokin SIT DEFiSIT musings
Old 18th December 2019, 08:52 AM   #21
Zen Mod is online now Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 18th December 2019, 01:08 PM   #22
woofertester is offline woofertester  United States
Originally Posted by Zen Mod View Post
This lash-up is un-degenerated and self-biasing. + / - 33V, ~1.5A 50 deg C.
The tempco of this DEFiSIT pair is only very sightly positive. It does not run away like a naked MOSFET runs away. I believe that this makes the temp stability problem only a matter of how big and/or efficient the heatsink is.
I think I have a feel for how this works. I have ordered some parts to see if I can get the self-biasing rail voltages lower for the same or even higher current.
Just waiting for parts in transit now.
Old 19th December 2019, 02:14 PM   #23
Default SIT accelerator
In the BAF 2016 talk by Nelson, he shows a schematic labeled "DEPLETION / ENHANCEMENT FOLLOWER 2"
That schematic sets the bias of the SIT more negative than the bias of the enhancement MOSFET.
I call this putting the brakes on the SIT.
What my pair of devices requires is applying the accelerator to the SIT.
A re-drawn schematic of my pair of devices is attached. The Vgs values are for power supplies of + / - 24V at Ids = 1.65A at 48 deg C with zero offset between output and power supplies common.
Old 19th December 2019, 06:14 PM   #24
claudio52 is offline claudio52  Italy
claudio52's Avatar
Location: Mediterranean Sea, near the Circe enchantress
Hi woofertester, take a look at post #108/DEF Amp. I think function 3 also adapts to Vgs of the PMos more negative of NJ.
Old 19th December 2019, 08:44 PM   #25
It looks to me that his SIT gate was more negative than his PMOS gate in all of the schematics on that page.
Old 20th December 2019, 02:55 PM   #26
claudio52's Avatar
Yes, it's true, I wanted to say that yours too string resistances with Vgs PMos > Vgs NJ, in absolute value, adjusts the output offset.
This is may last DEF experiment. There is the most negative FET enhancements mode. Before reaching a stable offset, Vos went up and then back down. DEF Ultimo schema-jpg 2.jpg
Old 20th December 2019, 07:13 PM   #27
I find that the output stage when cold has 150 mV of offset. The output stage is set for 0v offset at 50 deg C.
The offset is definitely dependent on temperature
My guess is that a resistor array with one or more thermistors can reduce the drift of offset over temperature.
A very gentle DC servo may be worth investigating.
My initial desire is to use this as a DC coupled follower much like an F4.
For the pair of devices that I am using, 67 mV is the difference between the two gate voltages.
Old 20th December 2019, 07:36 PM   #28
Zen Mod's Avatar
I care about DC offset when in temp equilibrium
while arriving there , I don't care even for 1V5 , it'll not harm even hysterical Lowthers and such , under sole condition that nothing is abrupt
Old 20th December 2019, 07:42 PM   #29
Good to know. I will not worry about it then.
If laying out a PCB, it should be simple to have a network and and a couple of jumpers that will handle the cases of SIT Vgs being either low or higher than P-FET Vgs.
Old 21st December 2019, 08:46 AM   #30
claudio52's Avatar
Thank you Zen Mod. An all the more reason to continue the studying the DEF Amp.
Tokin SIT DEFiSIT musingsHide this!Advertise here!
Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans Zen Mod Pass Labs 874 16th February 2019 03:49 PM
THF-51T old used 5pcs passed the test TOKIN from VGS= 4.3v ... pras1170 Vendor's Bazaar 9 21st December 2018 04:49 AM
FS Tokin THF-51S NOS dBel84 Swap Meet 0 22nd September 2018 08:32 PM
FS. TOKIN SIT 2SK180,2SK180C,TOKIN 2SK 180 D joshvi Swap Meet 46 24th August 2018 04:58 AM
NOS TOKIN 2SK180 V FETish Swap Meet 0 21st January 2018 09:57 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
