Actually, the match is for Vgs, not transconductance in order to trim the
bias current. Originally I tried to get as close a Vgs as possible, in an
effort to reduce the resistive degeneration, but then I developed a
technique to retain the "square law effect" independent of that.
Thank you Mr. Pass for correcting my assumption.
Is in second order the k2/k3 relation a bit shifted?
Your treasure chest is always full ...... )
So we have some stuff to think... as always.
Could that elusive cap glued to the bottom of the board be a bypass for the IRFP240 source resistor ?
More interesting than that.
inspired by SIT-3, but maybe idiotic.....
I was told that the source follower solution sounded worse compared to the DEF.
That is not the conclusion. The Source follower SIT is pretty close to
the DEFiSIT into 8 ohms at lower power levels, but falls short in terms
of output power.
All of this is just subjective opinion anyway. I will continue to explore the
DEF with the Jfet - I have those parts and the design has since morphed.
Joined 2009
Lower output means 10W for the Source follower SIT? DEF with the J-Fets....do you mean the J-Fet input pair or some SS at the output?
Yes 10 watts.
The Jfet is SS R085 or R110 depletion mode N channel part.
Now I have a good view of the photo with large screen.
Wander to know which scenario is happened first:
A) Mr Pass had bought a truck load of Antek double shielded toroids.
B) Mr Pass had bought a truck load of CineMag unshielded transformers.
Cheers
A happened first.
Plitron toroids are for " de Luxe " stuff
The Plitron Story: Parent Company of Torus Power Conditioning and Isolation Products - YouTube
Antek Inc. are very good quality and more Diyer pocket friendly
Antek Transformer First Impressions
A happened first.
Hi soundhappy,
You mean in case Mr Pass bought shielded input transformer by the truck load, wouldn’t he going to use Antek’s.
Cheers
- SIT-3
