SO more questions as I am ordering parts. Are all those 3 watt Resistors wirewound?
C5 should be a polarized capacitor?
Wirewound resistors can be used but metal film would probably be better.
C5 is a film cap preferable polypropylene but I have been know to use polyester to save money.
Wdecho picodunb replied some of them are Panasonic metal oxide resistors .
Also are you sure about the Cap? I remember seeing a board picture but it was a polarized cap I believe?
Metal oxide is a good choice as well. Judging by the schematic posted the C5 cap is not polarized. No + with the cap means non polarized. As far as the resistors as long as the value and power rating is correct there should be no difference in the sound between the type you choose. Cost usually determines what I use and that is determined by my bank account when I order. My funds also determine whether I buy 1% or 5% as well.
I used this calculator zen.
http://www.4pcb.com/trace-width-calculator.html
I guess the maximum current in the traces between 8-10Ampere.If it is 8 Amp then this traces are enough 3mm in thickness. But if it is 10amp may be not.
- First watt F2j with SJDP120R085
