Thanks Zen , but I want to play it safe. It is not easy to draw 5mm traces , that is why.i know 10mm is better but what is a good compromise. I seen the pictures of board from first watt. Does not look like 5mm but may be he used 5 Oz traces?
I spec heavy copper, which means different things to different vendors,
and the trace width is usually whatever fits the space I'm working with.
The main thing is, I don't get too excited about it, as the resistance values
are always lower than the other stuff in the circuit.
The main thing is, I don't get too excited about it,......
The SJEP could be thought of as an enhancement mode JFET, hence the "E" in SJEP. Since there aren't a lot of affordable power JFETs in production, you'll be probably looking for a SiC mosfet. Have a look at the part you're replacing and try to find something with similar (or lower) capacitance, Vgs, and transconductance. The F2 isn't a super fussy circuit. Try some stuff.
Will this Fet SCT10N120 a better option than SJEP ?
https://www.digikey.com/product-detail/en/stmicroelectronics/SCT10N120/497-16597-5-ND/6137190
Half the Ciss of SJEP120R
Of course Mike. Just paranoia sets in when you know they are the only two. What if I damage them etc.
of course that you can ....... but in this case SJDP is taking role of invisible part , while mosfet is still governing one .......... and entire circuit would remain (almost) same in sound character
practically -
Dear ZM,
Do you speak theoretically of from practical experience?
I ask because I will start cascoding all my amps, when time allows.. 🙁
The Sony TA-N7 sounds like a VFET amp and the small BJTs seam to be transparent...
Thanks,
M.
Dear ZM,
Do you speak theoretically of from practical experience?........
both
Hi
Couldn't find the R100 so just bought some Wolfspeed C2M0280120D.
For the power supply would a quiet 24Vdc, 5A (120W) per channel SMPS sufficient ?
My load is a 8 ohm full range. I have read on this forum that the amp draws at idle 35W per channel and somewhere else 75W. Which one is right so I can size my heatsinks properly?
Thanks for your help.
Eric
Eric
Thanks ZM,
So 75W dissipation for 5W output, correct ?
Is there a way to reduce bias from 2.7A if I'm only using 8 ohm speakers. Is the bias rated for 8 and 4 ohm load ?
F2 is rated 5W @ 8ohm and 10W @ 4 ohm, of course the 4 ohm load needs more current.
I'd really like to try the F2 but not if it requires 75W dissipation/ch.
Thanks,
Eric
Thanks,
Eric
F1 100W diss/ch 10W/8E/ch
F2 75W diss/ch 5W/8E/ch (10W/4E/ch)
F3 100W diss/ch 15W/8E/ch
F4 80W diss/ch 25W/8E/ch (buffer)
F5 60W diss/ch 25W/8E/ch
- First watt F2j with SJDP120R085
