FirstWatt J2
Someone asked for a larger image of the PCB.
Here you are.
Patrick
These are the cases I bought. The heatsinks and internal tunnel are the same as Patrick's. The only thing I would ask to be changed is the power switch on the front panel.
3415 all aluminum power amplifier on both sides of a small cooling chassis can be installed Wei Liang JC3 circuit-in Amplifier from Consumer Electronics on AliExpress
I printed out the UMS template and tape it on the heatsinks and punch the holes and drill those on a press. Tapping is the tricky part but it's not difficult.
Thanks for the AliExpress link twitchie on that enclosure - much cheaper there than on ebay, but then again that is no surprise these days.
How is the overall quality of the enclosure can I ask. I note your comment on the front panel power switch, I can live with that.
Gary..
J2 variant with IXTH16N50D2 current source
I am looking at the behavior of the IXTH16N50D2 as a current source for a J2 variant. At 24V, the source resistance to give 2A bias is around 0R8. The current is self-biasing with a reasonable tempco.
Would this make sense as the Mu follower current source for a J2? The idea is to skip the need for the opto bias.
I have the SS parts from Euvl's group buy.
