Manganin wire wound resistor diy
Joined 2017
Hello, I made 100R wire wound resistor with
0.08mm 114cm Manganin wire.
I have replaced on signal path resistor,
It's messy made and not stable.
0.08mm wire is so thin and fragile.
Actually it sounding pretty good.
Are there any advice or any experience?
Not sure how can you know *the resistor*
is sounding pretty good
You post not schematic, not sure what is it actually doing in that circuit.
"A Nelson Pass amplifier" is not enough.
IF amp has highish input impedance, as I guess (>5k?), 100 ohm in series will do nothing.
Why do you think a low value wirewound resistor is needed there?
What problem are you trying to solve?
Not sure how you mount it, care to show a picture?.
You definitely added an inductor and an electromagnetic antenna at a sensitive point.
Manganin wire is often seen used for its stabile characteristics in high quality metrology instruments, but achieving the level of stability often seen published requires a high level of expertise in fabricating manganin resistors. I suggest using manganin is not an applicable path to take for the OP's application or for a diyer.
Actually I wanted to try rhopoint Manganin wire wound resistors but 30 minimum order.
Zfoil and Manganin film are too bright in sound for me.
So very small inductance make sound smoother.
