Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Multi-Way Conventional loudspeakers with crossovers |
Thread Tools |
Boy, that took a while. Around 60 individually cut pieces per box, and filled to the brim. It’s so full that the drivers actually sit Securely at the height they’ll be mounted at, and the felt continues all the way to the back of the speaker. The baffle will be made from two layers of 1/4” maple, with a central layer of sorbothane, and mounted to the speaker with sorbothane gaskets. crossover points will be 500hz and 2.5khz
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain Last edited by Remlab; 27th September 2020 at 07:23 PM. |
#2 |
so how does it sound ?
#3 |
The baffles are yet to be made (The baffle parts haven't arrived yet) , but measurements will come in a couple weeks
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain |
#4 |
Drivers being used. The spec sheet states 84db on the mids, but they have been consistently measured by several users at around 87db, which is a much more usable efficiency rating. It actually makes sense because all of the other Peerless HDS drivers using this motor measure around 87 to 88db. Anyway, as you can see, it's extremely pistonic within it's operating range.
#5 |
What are you using for the bass driver?
#6 |
All peerless HDS based system(Not the midrange and tweeter you see here), Actually, the subs are Peerless XXLS but have the same cosmetics.
#7 |
I actually love what's on top right now, but I had these other things sitting around, so what the hell, I may as well see if I can outdo it. The Scanspeak 10f/8424 needs a little more EQ in it's passband than I'm comfortable with. I'd like to see if I can get a flatter midband response without the tweeking from my current project. I may also go with two layers of 1/4" aluminum plate with a constrained layer of Sorbothane instead of the maple I wrote about earlier, because the 1/4" maple just wont be rigid enough for what I'm trying to achieve
#8 |
Just bit the bullet. Four, 1/4" aluminum plates, 7" x 11" for the baffle.
#9 |
Nice tight fit. Now it’s time to ‘machine’ the plates.
#10 |
I have two more 1/8” aluminum Top plates coming(Equal to the outer dimensions of the speaker), so with the sorbothane, each baffle will be four layers and 3/4” thick.
It's not what you don't know that causes trouble. It's what you do know that just ain't so..Mark Twain Last edited by Remlab; 6th October 2020 at 03:17 PM. |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
US source for thick acoustic felt (box lining) | dainrobert | Parts | 4 | 29th March 2011 01:57 AM |
Modes and Nodes and Density - Acoustic Math help | Pulse-R | Everything Else | 3 | 26th March 2009 08:32 AM |
High density Fibreboard UK Supplier? | calvert73 | Subwoofers | 1 | 17th December 2008 11:57 PM |
26 pin High Density D Sub Plugs and Sockets | fmak | Parts | 3 | 4th August 2006 07:33 PM |
2" rigid high density fiberglass for acoustic room treatments? | darkmoebius | Room Acoustics & Mods | 6 | 6th May 2005 09:44 PM |
New To Site? | Need Help? |
