Increasing loading of midbass in synergy horn
Old 5th September 2019, 01:53 PM   #1
fers is offline fers  Canada
Default Increasing loading of midbass in synergy horn
I am designing a PA mid-top with efficiency as an important criteria.
The synergy horn is a nice approach and I'm inclined to try it. However, in a two-way synergy, the use of wide and short (to attain the directivity goal) conical horns implies rather poor loading at bass frequencies (say, 100-350 Hz). At first, it seems there is no way out of this, short of narrowing the coverage angle. Even going three-way, the horn loading (for reasonably sized cabinets) drops for the woofers and efficiency seems to only be recovered with the use of a large number of rather expensive drivers. As a different approach, I'm considering the use of a radial horn flare between the drivers and the port in the main conical horn. A few questions:
Phase:
The basic synergy design uses first order crossovers so that the phase shift induced is countered by the time shift between the drivers. Adding a length of horn between the driver and the port would break this balancing act, but I have seen designs that seem to use higher order crossovers (without dsp delay). Is the phase coherence lost in such cases?
Are most of the benefits of a synergy horn still available (without dsp) if, say, the signal at the ports is in phase with the 1/4 period delayed tweeter output at the crossover frequency, but with the mid output delayed by a fixed path delay that amounts to an integer multiple of 360 degree of phase at the crossover?
Reflections:
The junction between the mid ports and the main horn seems to constitute an impedance mismatch. This is not what the patent prescribes, but most actual designs do not seem to have the impedance matched at the port (and it does not even appear to be a design criteria). I can see how this might work using bandpass enclosures between the drivers and the horn as these acts as lumped components and, properly designed, will not allow resonant standing waves (but will demonstrate less than optimal power transfer / present reactive impedance to the driver). However, if a horn is substituted to the bandpass enclosure, then a significant impedance mismatch will lead to reflections at the port and problematic resonant peaks in the frequency response. Am I off the track with this consideration?
If the some of the benefits of the synergy horn could be retained, then the design may be worthwhile. I have simulated some rough ideas and I can drastically improve the bass frequency loading. Something similar might have been done in one of Danley's designs. However, I admit not being sure about what are the design considerations in this case.
Geoffroy
P.S. : The simulations are done with code I did myself, but it is harder for me to simulate integration with the tweeter in a synergy as I first need to think of how to approach the problem. Yes, I know hornresp exists, but I don't have a windows machine and wine doesn't want to play with me. Those simulations where verified with hornresp results on a borrowed laptop. On that note, if anybody knows the details of the multiple entry horn and offset horn model in hornresp, I'm all ears! You don't have to sugarcoat it, I play with maths for a living.
Old 5th September 2019, 04:58 PM   #2
mark100 is offline mark100  United States
Originally Posted by fers View Post
A few questions:
Phase:
Reflections:
I'm no synergy expert by any means, but I'll offer a few thoughts...
If folks are using higher order crossovers (like I'm currently doing with dsp before beginning experiments with 1st order),
phase coherence can be maintained by varying delays, but load sharing across drivers gets sacrificed.
re: having "the mid output delayed by a fixed path delay that amounts to an integer multiple of 360 degree of phase at the crossover?"
That would put the drivers in phase at crossover frequency, but out of time alignment. IOW, only the exact xover freq would be in phase.
The HF driver would need to be time delayed that amount too, to get back to full phase alignment.
re: reflections.
I share your questions about impedance mismatch between mid ports and horn. I saw in one of the patents it says the port area should equal the horn mouth area, but afaict ports are invariably smaller.
Hopefully, others will chime in here...
Have you seen the new Danley J7-95? Looks like horn loaded low drivers firing into horn ports....
One final thought/question... can any synergy design actually provide horn gain down to the lower mid bass (say 100-150Hz) without being physically huge? As in 11ft circumference and requisite length?
other than maybe horn loading before going into main horn ports...like you're contemplating I think ??
Old 6th September 2019, 03:58 AM   #3
Hmm, but then a dsp would be required. I thought the some of the Danley's, say, where using higher order crossovers without requiring a dsp. Moreover, thinking about it, the acoustical lowpass on the mid ports should add another 180 degree of phase which would also be problematic for preserving the time alignment, but I guess this could be taken care of by switching the polarity of one driver.
Indeed, but my hope was to get away with only having smooth phase throughout the crossover and not perfect time alignment. One should still retain the benefit of point source behaviour.
re: reflections.
Then it might be time for some experiments! Maybe a setup as simple as replacing the port chambers with a long plane wave tube would be enough to highlight impedance mismatch as peaks in the FR that would shift with the tube length. What do you think?
Indeed! It is hard to say, but it looks similar to the J6-42 I mentioned.
Regarding your final question, this is precisely what bothers me. I want to be able to run off battery and remain portable. I might have to look at a design more like msibilia's mid top if the "pre-horn loading" approach does not work out.
Old 6th September 2019, 02:42 PM   #4
I don't know of any Danleys using anything above 4th order crossovers...maybe there are?
I have the Danley SC-48 DSP processor that has presets for all their speakers, but haven't looked at every speaker...... if you have one in particular you want me to check, happy to do so.
The presets are mainly EQ's that ride on top of the passives in the speakers, or add linear phase 4th order crossovers if the speaker allows/is used, in biamp mode.
Having smooth phase alignment through the entire crossover region requires time alignment.
I think you'll loose a lot of point source behavior without full alignment.
Check out page 117 https://www.rationalacoustics.com/do...User-Guide.pdf
BTW, thx for your comments in the 'speaker cone mechanical energy' thread.
You give very technical but clearly stated explanations, which I still often don't understand
Old 6th September 2019, 08:32 PM   #5
Patrick Bateman is offline Patrick Bateman  United States
Patrick Bateman's Avatar
Ugh I really don't need another project, but I DO think that what you propose is valid.
Here is how I would do it:
We all know what Unity horns look like, here is my current project.
If you are prepared to use DSP in your Unity horn project, I think it is VERY possible to use *extremely* long midrange taps. Possibly as long as a foot, maybe even two feet!
The key to making this work is that you want the midrange taps to expand continuously.
Easiest way to do that is with very narrow midrange taps that expand from the throat up to the mouth.
Ok, now here's The Secret Sauce:
To make this work with a very long midrange tap, you'll want to mass load the tap.
This is a mass loaded transmission line.
Now, you're probably wondering, why mass loading?
Normally, we use mass loading to SHORTEN a horn or transmisssion line.
In this scenario, we'd use mass loading because it allows you to make the exits of the midrange tap much smaller.
For instance, you might have midrange taps that measure 12" x 1/2", but at the very last moment, at the exit of the Unity horn, the taps would 'neck down' to 6" x 1/4".
The idea is that we get the effect of a horn mouth that measures 12" x 1/2" but with a much smaller mouth, just 6" x 1/4".
You'd need Akabak to sim this by the way.
Old 6th September 2019, 09:26 PM   #6
Very interesting.
But I think the idea, the goal, has been about how to get more 100-350Hz output, than midrange output.
Hence the horn-loaded lows, leading into the main horn, thoughts...
Do your ideas extend into the woofer section too?
Old 7th September 2019, 12:18 AM   #7
What I describe could be used to horn load the midranges, the woofers, or both.
The "trick" is that you're putting the midranges or woofers into a horn, and then using DSP to line up the wavefronts as they enter the Unity horn.
Similar to what was described in the first post:
Old 7th September 2019, 07:07 AM   #8
Hmm... What about the J6-42 that seems to have those MLTL loaded woofer ports? Especially the delay settings for the woofer and the mids.
Old 7th September 2019, 07:50 AM   #9
Interesting idea. I would have thought that such a mass loading would remove a lot of the horn gain. On first thought, a port is a drastic change of impedance: I can see how it helps load the driver, but I would expect a lot of reflected power at the port. However, it seems bass reflex ports manage to get good efficiency from the port, although for the frequencies of concern in this case the box/port can be taken to be lumped elements.
I don't quite see why those reflections from the port are not a problem when the box/MLTL/ML-horn are too long to be considered lumped. Yes, damping can be used to remove some of the standing waves, but that would be at the cost of efficiency.
I'll try to run a few simulations to shed light on that.
Well, I code my own simulations in python from scratch... infinite versatility! I think I can do this case. It really is the multiple entry horn with more then one drivers that causes me problem as much of the code needs to be rewritten. I have to use multiports devices or figure out a way around that.
Old 7th September 2019, 08:16 AM   #10
Nope.
Because of Hoffman's Iron Law, the efficiency of a system is determined by it's volume and bandwidth.
The entire system basically behaves like a conventional front loaded horn, but with a segment in the middle that creates turbulence.
One way to visualize it might be like visualizing a freeway with six lanes that 'necks down' to two lanes, the expands back to six lanes.
That turbulence might seem like a big problem, but keep in mind that we really only care about the velocity at the mouth, not the velocity in the middle of the horn.
Increasing loading of midbass in synergy hornHide this!Advertise here!
Synergy Horn with AMT de45dd Multi-Way 40 27th July 2019 05:09 PM
Synergy horn for 135 dB+ Thijs666 Multi-Way 107 24th November 2018 05:07 PM
horn, bandpass, horn, synergy? fotsinijts Multi-Way 32 31st August 2018 10:30 AM
M2 Synergy Horn Patrick Bateman Multi-Way 43 23rd December 2017 03:08 PM
DIY Synergy horn paulspencer Multi-Way 53 5th December 2015 10:29 AM
Copyright ©1999-2019 diyAudio
