Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way? Please consider donating to help us continue to serve you.
Old 20th October 2019, 08:07 PM   #3761
GM is offline GM  United States
GM's Avatar
OK, what type of distortion is when drivers are emanating same/similar frequencies from different areas of the diaphragm?
Yes, but the point is to be able to stiffen a much larger area of the diaphragm to a higher frequency before it's no longer pistonic to keep from the above happening, or at least much reduced.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 20th October 2019, 11:48 PM   #3762
gedlee is offline gedlee  United States
gedlee's Avatar
GM
That would be "linear distortion", a frequency response change.
Earl Geddes Gedlee Website
Old 21st October 2019, 12:19 AM   #3763
GM's Avatar
OK, thanks! But having a driver stay linear to a much higher frequency reduce IMD?
GM
Old 21st October 2019, 06:48 AM   #3764
AllenB is offline AllenB  Australia
You might get 'non-linear distortion' with the suspension, the amp and the speaker motor, and a few others.
Old 21st October 2019, 08:08 AM   #3765
phase_accurate is offline phase_accurate
There is some truth in this. While breakup does not cause the nonlinearities by itself it can boost the HD and IMD products caused by the motor noinlinearities.
Charles
Old 21st October 2019, 11:25 AM   #3766
camplo is online now camplo
Originally Posted by gedlee View Post
What is known is that linear phenomena such as diffraction becomes more audible at higher SPLs which can also be heard as "dynamic contrast" and which, based on my research, is more likely to be the issue.
Wheres the data that shows that increases in diffraction results in the higher contrast of dynamics?
I'm starting to think the lack of IMD within a system is a strong factor for the subject since a driver has such small excursion vs output, within a proper horn system...
Old 21st October 2019, 12:49 PM   #3767
http://www.gedlee.com/Papers/AES06Gedlee_ll.pdf
The lack of nonlinear distortion is usually leading to lower subjective loudness perception - until you try to talk to the one sitting next to you …..
Charles
Old 21st October 2019, 01:17 PM   #3768
krivium is offline krivium  France
This is one of the reason you see inwall monitors in big control rooms ( low diffraction, second main reason is the gain in low end as situation about BSC is inverse, you gain up to 6db for low end from 200hz approximately) and multiway system ( lower imd amongst other).
The one in the link below is a 4 way, all Tad drivers ( 2x15"+ 2x12"+ TH+ Et) i can't remember the xover points but the Et was used to get rid of the bad breakup of the 2" cd.
The low end is mono iirc. All driven by Bryston amps and BSS active filtering ( last time i visited the place it may have changed since). The CR is HUGE and the picture doesn't render the space well ( the desk is almost 5meter width).
Google Image Result for https://www.innamoramento.net/fichiers/galeries/annuaire/65183.jpg
The sound is not bad and can be very LOUD but it is more impressive looking than it sounded good to me.
The main issue being the SSL 9000j which make comb filter heaven at listening position.
Old 21st October 2019, 02:21 PM   #3769
whgeiger is offline whgeiger  United States
Default Dessenting View
1) Size is a principal determinant of a compression drivers cost, and output capacity at its low frequency bound. Also in this region, the suspension, has modes of its own.
2) The diameter of the moving sub-system is not the sole nor principal determinant of its high frequency response. Geometry and material(s) used, are far more important. WHG
3) To the exclusion of 1) above, equivalent HF performance may be achieved using diaphragm diameters ranging from 1.5" to 5".
WHG
Old 21st October 2019, 02:31 PM   #3770
…. and this is refering to which post ???
Charles
Is it possible to cover the whole spectrum, high spl, low distortion with a 2-way?Hide this!Advertise here!
cascode distortion Spectrum. mashaffer Tubes / Valves 34 22nd January 2017 10:37 PM
6av5ga distortion spectrum enzoastro Tubes / Valves 14 30th January 2013 07:01 PM
Distortion spectrum vs feedback artosalo Tubes / Valves 62 8th December 2011 12:51 AM
What do you look for in the distortion spectrum? keantoken Solid State 13 13th May 2009 01:06 AM
Tailoring distortion spectrum syl Solid State 14 25th March 2002 08:32 PM
Copyright ©1999-2019 diyAudio
