Xover to filter woofer SB 23NRSX45-8
But SBA can be attenuate for 3/5 dBs😕
I think that considering the response from the right position, this point is now moot.
When you have the second speaker built, a measurement of both speakers sounding simultaneously will give you a clearer idea of the bass you will get. And the response under 200hz will no longer be the response of the left nor the right speaker, but somthing different.
Y no me vengas con que en el grave también hay estereo...😉😀
Both channels FR.
I am a bit surprised because when 2 speakers are measured simultaneously, as there is always a difference in time arrival from each speaker, this delay causes a lot of combing making the response in the mids and highs very cahotic, while yours is surprisingly smooth.😕
Do you see 2 separate main impulses on the impulse response screen?
Btw, in the modal region your last curves are no longer as alarming as the first ones...
Ok the 2 first impulses of each speaker can be seen, though of different amplitudes, which might be a result of hf attenuation on the first one.
There is about 1ms delay between them which should make for a dip at around 500 hz (that i don't see on your FR) and combing above that, but you have also plenty of strong early reflections that might smear that combing. Add also the smoothing on your measurement...
