rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 7th August 2020, 12:47 AM   #3041
emailtim is online now emailtim  United States
@pos,
Just wanted to say thank you very much for your wonderful software.
I was finally able to acquire a multi-channel DAC and add linear phase crossovers to the convolution filter mix. Here is a current in-room snapshot of the WIP.
Trying to learn a step at a time. Adding the additional channel convolution files is telling me my near decade old music PC is about ready for a heart and kidney transplant.
Old 5th September 2020, 10:29 AM   #3042
esl 63 is offline esl 63  Sweden
emailtim do you have a spectrogram without the timealignment fir filtering on?
It looks really good now!
Old 5th September 2020, 04:53 PM   #3043
Here is an early vertical wavelet of the right channel, but it may not be indicative of just time alignment filtering disabled.
I should make another set of filters with just the XOs in place.
Old 13th September 2020, 12:00 PM   #3044
Solve is offline Solve  Sweden
Solve's Avatar
What is the moderate,extensive,maximal optimization do?
Music is the only art in real time....
Old 17th September 2020, 11:25 PM   #3045
pos is offline pos  Europe
pos's Avatar
It dictates how many iterations the optimizer will do to try to make the resulting magnitude curve as close as possible to the target one.
If you have enough taps at hand setting it to "none" (default) is the best option.
waveTracing | rePhase
Old 2nd October 2020, 09:29 PM   #3046
rubofdagreen is offline rubofdagreen  United States
I have saved files for Linear phase filters as texts files on many occasions. But I have no Idea how I did it. Can anyone help a senile senior citizen? Thanking you in advance for all the wonderful and amazing toys I enjoy!
Old 2nd October 2020, 10:38 PM   #3047
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
Try the "format" dialog or use wav-files imported to REW that can also export txt-files..
rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool-rubofdagreen_x1x1_200ms-gif
Old 2nd October 2020, 11:00 PM   #3048
I apologize for not being more lucid. The file is associated to notebook as opposed to rephase. A sample would be like this.
0.000000222327485354002
0.000000242728855243869
0.000000263238293167602
0.000000283914510736799
0.000000304815024240466
0.000000325996114626483
0.000000347512788535151
0.000000369418740381895
0.000000391766315486656
0.000000414606474247842
0.000000437988757359172
0.000000461961252068117
0.000000486570559475232
0.000000511861762873963
0.000000537878397131111
0.000000564662419108662
0.000000592254179128006
0.000000620692393478308
0.000000650014117971105
0.000000680254722543869
0.000000711447866915686
But if I add TXT to the file as I save it I am getting this, which is not helpful with my preamp Najda.
rePhase settings
eNp1VMuS2yAQ/BUVp6TWJugt/A05JLluuVRjC9vUClAArdfZ2n/PgCSXnXgvQtPN9DRoRu9kZ97a
g+y9sI5snrcrshcaA6mPZEOU7LpeEARPYv/iRoVYncEOWNcIzkE0HYMm3xdl3TRQ5awEHnZb49y9
KgZCgxIo0JszCYC92fEc0PUAziH1XeqXs/R/1r8w6YJAVoQHLRkujNasxrVkjGyDsLEKPMrmWfIt
qYpkJ71LDr0BXHqphUu+UP/mv5Jlb/uKNaXRmJNS1iB+BBmip5yyUOkofqOldwJ7L1/RcboiCt7C
9gzZ4QROtFb04CcRJbVUo1pHAjf4yxCOuTfaedA++YnYK/SjmA66Thnl4SR5RfMyrLTGhW1Xgctp
HrimpsEYp7y4UnNayoOLPKVpM1NPDWWByXhUIjVd9J5qmsacyK N4yJ3kyqlQimA5cQ1fsqqJqxsa
bjptaFovafVsoi5iGqeLIJs8VGiCV/FzsXsGPbCHeImHLR4xWZnyeA3/McUnWlVecPpZ9Zo/JKpP
tLIy5zfFtx/YbEcLw6l1wnucj7mz77HWgn6JLSPvGhw3KgFutELhfJHNO9ldY rtvGM6LUYPQDryI
YQceMEWPfb+6f2ynXm3N4YAFscmC0ZPsRKvgGHNjMHViCKXGZv fx1UslbhM/VkSbUJGghhmQln+W
ltZGi3/QFkfKWOTWUzMNcUjQ0GB6sNJfYppVSDlQQ39TKw7jgk8/lqKZbt2Zgz+DDS6s+DEP0AK2
btzN/4wH5O0UFzQP1Li7v3EPA76RMk3JfP5OWrG/HjK6vY6rnank+n1X5Cx1Z86TZz16D31PPv4C
GSZ3AQ==
Thank you for your help!
Old 2nd October 2020, 11:46 PM   #3049
fluid is offline fluid  Australia
If you choose the text output option as Byrtt showed and press generate to save the file. Open that file in Notepad you will have all the coefficients as you want.
Perhaps you are looking at a Rephase settings file which is why it looks weird in notepad.
Old 3rd October 2020, 12:32 AM   #3050
BYRTT's Avatar
Try this, hope it helps..
rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool-rubofdagreen_2_x1x1_500ms-gif
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
