rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 16th May 2020, 11:27 PM   #3021
emailtim is offline emailtim  United States
Default Phase Presets Tip
Please disregard if this has been discussed before.
I stumbled on a convenient way to adjust phase.
Reserve 4 banks for phase.
  • Preset the 1st bank for "flat 2/3 oct".
  • Preset the 2nd bank for "flat 1/3 oct low freq"
  • Preset the 3rd bank for "flat 1/3 oct mid freq"
  • Preset the 4th bank for "flat 1/3 oct high freq"
Use the 1st bank to enter course adjustments.
Use banks [2-4] to layer fine adjustments on top of the course adjustments.
Old 9th June 2020, 12:26 PM   #3022
c76 is offline c76
Default Phase Offset
Hello,
If I were to equalize all drivers seperately, on seperate channels with seperate impulse response convolutions, how would I add a phase offset of +360 to the tweeters to compensate for the lagging behind of the woofers due to the LR4 crossover?
From what I understand the "Filters Linearization" tab is of no use here, because im using seperate channels.
Thank in advance you for your help.
Old 10th June 2020, 09:53 AM   #3023
pos is online now pos  Europe
pos's Avatar
Are you trying to build a minimum-phase crossover, or a linear-phase one?
waveTracing | rePhase
Old 10th June 2020, 10:37 AM   #3024
c76 is offline c76
Thank you for your reply,
I am building a linear-phase crossover.
Old 10th June 2020, 12:56 PM   #3025
pos's Avatar
Luckily phase tracking is much easier to get right when building an acoustical linear-phase crossover compared to a minimal-phase one.
Try following these steps: rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 10th June 2020, 01:05 PM   #3026
454Casull is offline 454Casull  Canada
Not sure if it didn't work for anyone else, but here's another link to try if it didn't:
Old 10th June 2020, 01:24 PM   #3027
pos's Avatar
This links to the same post, at least from my browser.
Old 10th June 2020, 01:29 PM   #3028
It didn't on mine. I think it's because your link has a reference to the page number, and the page number doesn't match up with my account settings (it's like... page 68? that thread only goes up to page 61 for me) whereas my link seems to be page-agnostic.
Old 10th June 2020, 01:31 PM   #3029
pos's Avatar
Good to know, thanks!
Old 10th June 2020, 01:41 PM   #3030
I think I know what happened... you probably grabbed the URL after you clicked through your target link. This is the URL I get after I click my link:
Same format as your link, which is different from the page-agnostic link that I directly captured from the #xxx link in the top-right of the post:
It makes a difference, apparently.
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
