rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool Please consider donating to help us continue to serve you.
Old 26th November 2019, 08:55 PM   #2881
Oabeieo is offline Oabeieo  United States
Originally Posted by fluid View Post
It would probably be useful to get a measurement without any processing or EQ, to see what the basic driver response is. With that sort of cabin gain you might be better off eq'ing the slope to what you want rather than flattening and using a textbook crossover. You might get some gain back that way.
Try a close mic measurement as well to see the difference in phase, because something is sending your phase the wrong way.
FDW is just different gate lengths at different frequencies and can be helpful to see the direct wavefront before it gets messed up by the room/cabin. In your measurement reflections are happening early due to the small space. I don't understand what a FDW and minimum phase have to do with each other?
Why not use it if it helps you to see what is happening?
Thank you FLUID
Okay so Iíll try just that today. We have a snow day in Colorado got to talk the wife into letting me play for a little while.
I stayed up till 3am last night working on the system.
It sounding better than Dirac as far as ambiance, imaging , and harmonic balance. My 2118h midrange are extremely hard to get right.
The differences between left and right responce are so extreme that doing seperate left and right eq de-correlates the phase between left and right.
Where Dirac somehow manages it much better. I really want to figure out how to get that eq work done right and maintain spectral balance in the time domain.
So Iíll be hoping I can get help with that later, for now Iím going continue to get the sub farther nailed down. Iíll start with the sub and work my way up from there.
Iíll get some measurements of the sub just like you described and see if I can make the stopband have better attenuation. I also noticed that and tried adding a iir lowpass and it changed the timing negatively.
Perhaps maybe to do a 24db linearization whilst using a 48db filter or something to that effect.
But I agree, Iíll have to bypass the fir and crossovers and take driver measurements. Iíll see if I can do that today sometime :-)
Old 27th November 2019, 01:05 AM   #2882
Here is the link to my drop box that has the .mdat that has sub measurements
close mic and back seat and driver seat and passenger seat. All no processing
the last measurements also did not have processing. I just remembered that I sent my soundcard directly into amps. I do now remember my sub amp (Rockford bd100a1) has a 12db BW dial on it that can not be turned off. I think I have it turned up all the way to like 400hz. Now I know why there's sub timing has been strange. I completely forgot about this.
As far as the sub polar being backwards , I wonder if its the amp polar response or something to do with amp.
I also took some measurements of the 2118H close mic, 1foot away and a driver seat reference mic location for time alignment to left and right. (similar to the 1st Dirac measurement point)
you can see how the 2118h goes to complete s*** at the reference position.
Any ideas welcome
Thanks in advance.
PM me if anyone wants to help me on the side for a consulting fee. I am egar to learn!
If I export the measurement to rephrase with excess phase can I just do a invert time function after my MPEQ (minimum phase eq) work is done?
Dropbox - sub and 2118h.zip - Simplify your life
Old 28th November 2019, 11:44 AM   #2883
fluid is offline fluid  Australia
Your close mic measurements show that your drivers behave more as expected, but the phase is still a long way from being minimum phase. See how your phase has a similar shape to minimum up to 70 Hz but is a full turn out of phase, then it goes away. There are no big jumps in the unwrapped phase which usually come from reflections. That could be your mic, your equipment or something, but if you plan on using your measurements for phase correction you should work out what is causing it and if you can remove it.
I have attached an example of a close mic measurement of a single TC9 driver I made. The phase is pretty close to minimum as shown by the grey trace.
When you overlay the close mic and drivers seat sub plots and adjust for level it shows what the cabin is adding. A lot of boost with 80Hz and 27Hz boundary dips. Fairly easy to EQ close to flat with only a few filters.
Your sub seems to extend quite high but your midbass does not go so low. You might want to make your crossover closer to 100Hz and try that.
I have overlaid some textbook curves at 80Hz LR4 and and 1Octave overlap at 100Hz from rephase to show what they look like. If it were me I would EQ the driver to the flat part of the line by removing the peaks above and leave the dips in. If you are using LR24 filters on top of that response you will get quite steep crossovers acoustically. Work out what you are aiming for acoustically overlay that with examples from rephase and see what filters you need to hit those slopes.
File Type: png Screen Shot 2019-11-28 at 8.50.51 pm.png (206.0 KB, 147 views)
Old 29th November 2019, 01:29 AM   #2884
Fluid,
Gosh you really know how to make things make sense to me. I have a lot of missing links that your helping so much with. I love how you overlay that. I need to start doing that! Now I see so much better and the smoothing! Aah yes!
I’ve been printing out the responses and looking at them side by side. That is so much easier!
The 2118h is my midrange , I have 2 pair of Stevens audio MB-6 high efficiency midbass drivers playing from 80-200 (sometimes300) I have those two pair of 6.5” in each door (4doors) there about 93db midQ, fs60 ,6mm overhang, awesome little midbass drivers. I have the midbass diialed in. They sound spectacular! The 2118h is a midrange that I am having a hard time getting to sound right that’s why I posted that.
The midbass are Lr4 complimentary 80-200 and the 2118H is LR8 complimentary 200-1.4khz I have noticed much better on and off axis behavior using the LR8on the 2118 and the stage rises a lot with the LR8 on those speakers so I’ve stuck with that.
The horn plays 1.4k LR4 and up, I like the way it sounds with the horn overlapping the midrange a little.
The sub amp I discovered has a built in BW24 crossover that is adjustable from 50-250 and I can’t tell exactly where it’s t it’s a knob with no detents. So I turned the knob up all the way so it should be 250hz BW24. I added to the sub fir a 268hz LR4 linearization and used phase eq to wiggle it into a BW24 linearization. I just realized that the sub had that crossover knob since you said the phase is running backward. So thank you! I forgot that it had that.
The linearization I added I also added the LR4 linearization to the same fir.
The sub sounds much more in time now. I need to remeasure it now and see if the phase is still goofy.
So this is what I need help with the most;
It’s in a car so it’s only for one seat. So there is no worries about other seats or phase issues other than the one seat. That in mind,
What steps do I need to take to correct for the time domain between left and right? Like a room correction, for a gloabal 2ch correction with unequal path lengths?
Let’s say the drivers are all time aligned and the crossovers worked out and everything is sounding good and levels and everything is set. What do I do in the opendrc for a two channel room correction fir assuming everything else is all setup.
What order do I do things and what am I looking for.
Or tell me where I wrong, does it go
1. Take left and right measurements at reference point ( center of head equivalent)
2. Remove any time of flight delay
3. Okay step 3 is where I get stuck , if I eq left and right seperate they de-correlate. How to I do seperate left and right eq without de-correlation. Or do I eq left and right seperate and that gets fixed later with phase correction?
4. So you have let’s say the left channel impulse in REW. You remove time delay
And generate minimum phase , add FDW and export the magnitude and excess phase at txt to rephase
5. Import the impulse into rephase. In rephase I want to see the magnitude and the excess phase with a FDW that was applied in rew.
6.what do I do with the phase!? do I try to make it look like the minimum phase? What is the goal? And how do I do left and right so the transfer functions match each other without screwing up the phase by using minimum phase one one channel and not the other.
I’ve read all the how to’s like Swiss bears how to and a few others but there vague and don’t say much about correlation or coherency between left and right.
Just a basic understanding of the basic steps and I’m sure I will take off and will be able to start to make some great sounding filters. I’ve been stuck at this stage of learning for awhile now and am desperate to figure out what the goal is and some basic how to get there.
I have in REW phase , minimum phase and excess phase. I understand minimum phase enough now, excess phase I understand as the room phase that is added to minimum phase....what about plain phase....is that the sum of minimum and excess I would assume. When doing left and right eq would I simply be able to make the magnitude flat on each respective channel than make the plain phase flat with phase eq for both sides? Would that correct for the diffrent minimum phase eq settings time differences and the room at the same time?
Some basic insight would be helpful, and I wasn’t kidding about a donation.
I called my local sound studio and talked to an engineer here in Denver and asked for tutoring and he said that what I am asking to learn isn’t taught that far in depth and he doesn’t know. It makes me feel like only the ppl that post in this thread and the like are like the only ppl on earth that know how to do this. I can’t find anyone that can teach me.
I also have a bunch of friends on another forum waiting for me to learn this because that also want me to teach them. So there’s a lot of us that are very excited to make the next big step
So much appreciated!
And I’ll check that soundcard. It’s a creative sound blaster usb sound card that has all kinds of outputs and inputs and has a flat response. Maybe I’ll do a soundcard calibration and try again.
Old 29th November 2019, 10:51 AM   #2885
Originally Posted by Oabeieo View Post
The sub amp I discovered has a built in BW24 crossover that is adjustable from 50-250 and I canít tell exactly where itís t itís a knob with no detents. So I turned the knob up all the way so it should be 250hz BW24. I added to the sub fir a 268hz LR4 linearization and used phase eq to wiggle it into a BW24 linearization. I just realized that the sub had that crossover knob since you said the phase is running backward. So thank you! I forgot that it had that.
I would measure your amplifier at very low volume with REW, less than 0.7V output maybe less to avoid frying your soundcard. Do a search you will find plenty of guides on how to do it.
That will show you what the amp is doing, it should then be possible to create an inverse filter to undo whatever the amp is doing that you don't want.
I have attached a shot of your close mic'ed 2118, this shows good matching to minimum phase before reflections get in the way. That demonstrates that your setup is capable of proper measurements and it is most likely the amp that is causing trouble on the sub measurement.
I have also attached a shot of the drivers seat 2118, with wrapped and unwrapped phase. You can see the jump from the reflections but in the wrapped one you can see the phase still follows the general trend of the minimum phase shape apart from the wraps at reflection points.
I have also done a quick REW auto EQ on that driver to show it isn't that bad with a bit of EQ. Then one with an LR8 @1400Hz.
Letís say the drivers are all time aligned and the crossovers worked out and everything is sounding good and levels and everything is set. What do I do in the opendrc for a two channel room correction fir assuming everything else is all setup.
To set the relative delays start with a single point measurement in your head position. Use REW's acoustic timing reference to find the difference in time of flight from the various drivers. Set those delays in your minidsp. Measure with your crossovers and see what you get.
4. So you have letís say the left channel impulse in REW. You remove time delay
1 and 2 make sense as above.
3 I don't understand, de-correlation. You want to EQ the left and right drivers so they have as similar a frequency response as you can without trying to fill in the big dips. Make it flat to start with and add the room curve after as global EQ. For now I would only use phase correction to undo the phase turn of your IIR crossovers through filters linearization in rephase.
If you have time aligned the drivers properly and undone the phase turn from your crossovers you should be pretty close to a good step response and minimum phase without anything else.
Then you can measure the left and right channels at the reference point to see what you have got. Apply a frequency dependent window of 15 cycles or less and see what it looks like. Compare the measured phase to the generated minimum phase. Then decide if you think more phase correction is a good idea.
Iíve read all the how toís like Swiss bears how to and a few others but there vague and donít say much about correlation or coherency between left and right.
As above make them as similar as you can and as close to flat without filling big dips. Example in the auto EQ screenshot.
Just a basic understanding of the basic steps and Iím sure I will take off and will be able to start to make some great sounding filters. Iíve been stuck at this stage of learning for awhile now and am desperate to figure out what the goal is and some basic how to get there.
The goal is sound that you are happy with
Excess phase is anything other than the minimum phase, it can be from reflections but it could be other sources of non minimum phase behaviour.
What you call plain phase is the measured phase. If your measuring setup is good that should be a representation of what you have. Make sure to include your mic calibration file in your REW measurements. I don't have it so my screenshots don't take it into account.
A speaker is a minimum phase device. If you use minimum phase EQ to correct the amplitude it will correct the phase at the same time.
There are not many situations where trying to correct the phase from reflections will work well. You need a good understanding of what the problem is to decide whether you should try. If not leave it alone.
Any form of phase correction should be the last step. Frequency response, time alignment and crossover optimisation should be your first priorities.
Some basic insight would be helpful, and I wasnít kidding about a donation.
I called my local sound studio and talked to an engineer here in Denver and asked for tutoring and he said that what I am asking to learn isnít taught that far in depth and he doesnít know. It makes me feel like only the ppl that post in this thread and the like are like the only ppl on earth that know how to do this. I canít find anyone that can teach me.
Recording engineer is probably not the best person to talk to about designing a speaker Huge amount of information here on diyaudio. Do a google site search of diyaudio for the terms you are trying to get your head around.
File Type: png Screen Shot 2019-11-29 at 6.37.46 pm.png (424.2 KB, 18 views)
File Type: png Screen Shot 2019-11-29 at 6.38.11 pm.png (88.4 KB, 16 views)
Old 29th November 2019, 06:24 PM   #2886
THATS IT! ah ha! Okay!!!!!
Oh yes! I finally starting to get it now. Oh I wish it wasn’t Black Friday I would be measuring today. This is so exciting. Thank you FLUID!
So here’s where I’ve been screwing it up this whole time,
I have been using moving mic spectral averaging RTA with pink noise to make everything flat. I need to do time averaging. I have always liked the spacial averaging sound way better than using measurement points and averaging them. For this process that must be my problem as I’m doing or it’s adding the room reflections to the average. I need to take those out.
I can’t wait to try this now. Maybe that is what’s causing the de-correlation.
And what I meant by de-correlate is the center image goes away and the phase coherence between left and right falls apart.
In a car there is radical differences between left and right. If let’s say you have a 8db peak at 200 on the left side and a 8db peak at 400 on the right and there’s a 1.2ms time difference and you use time delay to correct for that (which delay as we all know is only a alignment at some frequencies because the acoustic origin is fixed where the acoustic center can be changed with delay) and try to EQ that the phase between drivers gets changed radically.
But I have a hunch now with time averaging I’m only correcting frequencies that are minimum phase and not non minimum phase. Your overlay massively helps me see that!
I’ve been getting screwed up thinking I need to see the overlay in rephase, but all I have to do is move it all to a straight line and that will make it minimum phase again. I did not understand that! Yes it makes sense now.
I am so excited to try this! I’ll do exactly as you said with the impulse peak alignment in rew for each driver. Yes that seems like an excellent approach indeed!
Your a rockstar FLUID , btw there’s some big car audio names filling this thread now. We all are anxiously waiting for this to work right. I’ve been trying so hard to make it make sense. Dirac has a way of doing left and right eq so very nice but it has its issues with tonality that rephase allows me to choose what gets corrected or not or worked on or not. I’m so excited now. I can’t wait to start measurements!
This is it! This is the big one for me. I so much can’t wait to try this.
Old 29th November 2019, 10:25 PM   #2887
Oh yes! I finally starting to get it now. Oh I wish it wasnít Black Friday I would be measuring today. This is so exciting. Thank you FLUID!
Maybe see if there is a sub amp that has no filtering going cheap
So hereís where Iíve been screwing it up this whole time,
I have been using moving mic spectral averaging RTA with pink noise to make everything flat. I need to do time averaging. I have always liked the spacial averaging sound way better than using measurement points and averaging them. For this process that must be my problem as Iím doing or itís adding the room reflections to the average. I need to take those out.
Using moving mic with an RTA will work better for overall target curve style correction than it will for setting up a crossover. For individual EQ you want to be correcting the speaker and not the environment. There are a number of ways to try and get the room out of the measurement. Spatial averaging or impulse averaging is a good way. As outlined in Swiss Bear's tutorial and discussed before. The other is using a frequency dependant window and that works well enough on a single point measurement.
I canít wait to try this now. Maybe that is whatís causing the de-correlation.
A strong central image usually comes from having the left and right speakers being very similar in frequency response and sitting in the mid point between them. That is going to be different for a car.
In a car there is radical differences between left and right. If letís say you have a 8db peak at 200 on the left side and a 8db peak at 400 on the right and thereís a 1.2ms time difference and you use time delay to correct for that (which delay as we all know is only a alignment at some frequencies because the acoustic origin is fixed where the acoustic center can be changed with delay) and try to EQ that the phase between drivers gets changed radically.
Pure digital delay is the same at all frequencies, the whole point of using time delay in an active system is to correct for the acoustic centre differences of drivers that are not coincident.
But I have a hunch now with time averaging Iím only correcting frequencies that are minimum phase and not non minimum phase. Your overlay massively helps me see that!
Not sure I understand how that helps you understand
Iíve been getting screwed up thinking I need to see the overlay in rephase, but all I have to do is move it all to a straight line and that will make it minimum phase again. I did not understand that! Yes it makes sense now.
Kind of, just don't try and EQ the big dips out and you will be correcting the parts that are behaving as minimum phase. Minimum phase eq will fix amplitude and phase at the same time in that situation.
I am so excited to try this! Iíll do exactly as you said with the impulse peak alignment in rew for each driver. Yes that seems like an excellent approach indeed!
Start with aligning all the left drivers together, then the right together, at that point you can decide on a relative delay between left and right channels which may help you to get the imaging where you want it to be. A sub can be hard to align in this way because it does not have a sharp impulse, some trial and error might be needed. The step response will show if you have it aligned well or not.
Iíve been trying so hard to make it make sense. Dirac has a way of doing left and right eq so very nice but it has its issues with tonality that rephase allows me to choose what gets corrected or not or worked on or not. Iím so excited now. I canít wait to start measurements!
When you have the drivers aligned and EQ'd individually, dirac will have a much easier time, so it might be worth trying it again when you have done some manual tweaking.
Old 30th November 2019, 06:50 AM   #2888
That’s fantastic! Yeah I will definitely not forget any of this and I’m sure I’ll be going back and re-reading this along the way along with Swiss bears how to.
So I was under the impression that with unequal path lengths even with signal delay used for time alignment because of the unequal path lengths there would be comb-filtering and because of the physical distance the time alignment only works at frequencies greater than 1 wavelength compared to the path length differences (especially between left and right channels)
For example , speaker pair that plays midbass and/or midrange, the left is let’s say 1/2 wavelength of let’s say 300hz and the right side is one full wavelength of 300hz.
You set the digital delays so both left and right arrive to you at the same time.
The left side starts to play 300hz and arrives at -180 and the right arrives at +180 however they arrive at the same time. The physical distances cause the comb-filtering and the use of the delays is what makes the comb filters emerge.
In this instance (the way I understand it to be and please correct me If I am wrong), the right side if the use of MP-EQ to bring the level down so that frequency is not right side biased and where let’s say 600hz (it’s oactave) would flip where the driver side is at +180 and pssanger at -180. This seems to be a issue and the way I understand things to be and why I see this type of interaction in the mid-bass.
One might think; well no , actually if there’s a 1ms path length difference and you delay 1ms the wavefronts all arrive in phase the same as if you had equal path lengths. (Which is the argument I also understand). Which may be the case, but want happens at 1/2 octaves and octaves above or below the frequencies where there both left and right are at +180 or whatever. It seems to me that the physical offset causes comb filters and trying to eq them to have the same response causes massive phase problems.
And these problems must have eq. The differences in amplitude between left and right are so severe it has to be corrected. So this is where I’m really putting my faith into getting the system to be minimum phase and seeing how that affects the ability to eq the left and right without these issues.
I know everyone says don’t boost the dips. And I wouldn’t want to, however the comb filters are so many from a 4way and each pair suffering from the above issues at all different frequencies because of different pairs being placed in different spots, this almost makes eq work on some of the dips a must.
So in car audio we cut the peaks and don’t boost into anything until we get into the 2db range. If we use the same eq on both channels and just eq the sum of L and R the system sounds great. Once left right eq is applied some frequencies can tolerate it (highs) and some make the speaker go out of phase and the center vanishes.
So again. I’m really counting on this to work. I can’t wait to start measurements. I’ve read all the Dirac pages and they seem to be doing the same stuff rephase is doing. It’s all the same talk. Getting a minimum phase system. I so much want to be able to do my own Dirac correction except do it my way the way I like the eq work done and .....nuff said
I’m actually a car Audio installer by trade and manage a very busy store, so this weekend in retail I’m cooked. I won’t be able to do measurements till at least Monday or Tuesday. And I have a brand new set of beyma 8G40s coming to replace the 2118H (should be here tomorrow) so few more days and it’s on!
Thanks again for the help. I can’t wait to try this :-)
Old 30th November 2019, 08:40 AM   #2889
We aren't in a car audio forum here and I have no first hand experience with car audio, other than driving in different cars and being disappointed by the sound in most
That being said the underlying physics and acoustics involved does not change because you are in a car, but it does change significantly how well any of the strategies that make better home speakers will translate to a car. You'll have to experiment with that yourself to see what you get.
The delay changes when the speaker will start it does not alter the physical path length and it will not change change any comb filter pattern caused by a driver interacting with it's environment. You could get a change from separate drivers interacting with each other. That is why it is a good idea to set the delays first on each channel and see how that affects the overall response on each channel. If the drivers are not time aligned then applying textbook crossovers and linearizing their phase will not result in a textbook combination. Measure the result after time aligning and applying crossovers. Do you get what you thought you would? If not why not.
For example , speaker pair that plays midbass and/or midrange, the left is letís say 1/2 wavelength of letís say 300hz and the right side is one full wavelength of 300hz.
I don't understand what you are getting at.
There are two places where you might consider using delays. The first is to try and align the speakers forming the left (or right) channel together. The second is trying to delay the left or right channel to overcome the fact that you are not sitting in the centre between the channels. The first one should be more straightforward, the second one is where what you are describing is more likely to appear.
In this instance (the way I understand it to be and please correct me If I am wrong), the right side if the use of MP-EQ to bring the level down so that frequency is not right side biased and where letís say 600hz (itís oactave) would flip where the driver side is at +180 and pssanger at -180. This seems to be a issue and the way I understand things to be and why I see this type of interaction in the mid-bass.
I don't understand why you would use EQ, if a speaker is more dominant because of position then changing the level would seem to be the solution.
One might think; well no , actually if thereís a 1ms path length difference and you delay 1ms the wavefronts all arrive in phase the same as if you had equal path lengths. (Which is the argument I also understand). Which may be the case, but want happens at 1/2 octaves and octaves above or below the frequencies where there both left and right are at +180 or whatever. It seems to me that the physical offset causes comb filters and trying to eq them to have the same response causes massive phase problems.
I don't really understand this either.
And these problems must have eq. The differences in amplitude between left and right are so severe it has to be corrected. So this is where Iím really putting my faith into getting the system to be minimum phase and seeing how that affects the ability to eq the left and right without these issues.
Why not change the level if it's a level problem
I know everyone says donít boost the dips. And I wouldnít want to, however the comb filters are so many from a 4way and each pair suffering from the above issues at all different frequencies because of different pairs being placed in different spots, this almost makes eq work on some of the dips a must.
That is why you need to look closely at the measurements and compare close mic'ed to listening position. Is it a dip inherent to the driver, in which case you should be able to fill it. If it is a boundary dip, a null, then filling it will not work and the dip will just come straight back. You can take a measurement full of nulls and dips from boundary interference and EQ out all of those dips so that they disappear on a computer screen. You get a lovely flat line, your job is done. Then you measure it with the correction applied. Hang on where did all my EQ go You can try and fill the edges of the dip by using low Q EQ and that might work to improve things. Only way to know is to measure and see what you get with different amounts.
So in car audio we cut the peaks and donít boost into anything until we get into the 2db range. If we use the same eq on both channels and just eq the sum of L and R the system sounds great. Once left right eq is applied some frequencies can tolerate it (highs) and some make the speaker go out of phase and the center vanishes.
If using the same drivers on each side then using the same EQ makes sense as you are using speaker EQ rather than environment EQ.
So again. Iím really counting on this to work. I canít wait to start measurements. Iíve read all the Dirac pages and they seem to be doing the same stuff rephase is doing. Itís all the same talk. Getting a minimum phase system. I so much want to be able to do my own Dirac correction except do it my way the way I like the eq work done and .....nuff said
I use DRC FIR because I can change everything about it to get the result I want so I'm with you there.
Iím actually a car Audio installer by trade and manage a very busy store, so this weekend in retail Iím cooked. I wonít be able to do measurements till at least Monday or Tuesday. And I have a brand new set of beyma 8G40s coming to replace the 2118H (should be here tomorrow) so few more days and itís on!
Good luck
Old 30th November 2019, 03:57 PM   #2890
I love it!
Just wanted to throw out that last argument to see what you think of that logic.
And your very consistent, you definitely know a lot about this stuff. Iím so excited to try this.
So than okay, I will follow exactly that and completely re-train my brain and give this a honest go at it. Iíll make sure to be patient and follow exactly that. That makes solid common sense and is in step with everything Iíve read.
I only asked targeted questions to see if doing this type of correction changes anything in the ďnormĒ of tuning considering unequal path lengths.
And yes levels do make a big difference. However some core frequencies in most cars have two or three big comb-filters that need to be dealt with in one way or another. Just wanted to see what your thoughts were and if that changes how to do the process.
So Iíll do exactly what you said. Iíll tune align all the left speakers to a reference mic position, and make the correction , than do the right channel. Than time align left and right after each correction and listen and measure the sum and go from there.
Thanks again Fluid and thank you for the time to teach me. You know how managing 4 dsps can be all with different delays and such to offset for all the diffrent fir and all the time it takes to get something. Now that I have a clue on how to do this I feel like I have a small degree of confidence thanks to you guys. This is super cool. Best community and smartest ppl here, I feel so much gratitude for all the help.
Iíll definitely keep you guys posted on how it turns out.
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 02:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 09:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 04:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 08:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 11:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
