rePhase, a loudspeaker phase linearization, EQ and FIR filtering tool
Old 30th April 2017, 01:23 PM   #2021
thierry38 is offline thierry38  France
Maybe with this kind of correction:
using phase EQ (range +-180)
something like this,or several narrow band,according to the measurement (and the frequency of the null).
Old 30th April 2017, 01:33 PM   #2022
torgeirs is offline torgeirs  Norway
Do the Woofers have seperate FIR filters/amps
Old 30th April 2017, 02:19 PM   #2023
bcodemz is offline bcodemz  Canada
Yes.
I'm trying to do like a shelf filter for phase, something that'll increase phase shift by a constant amount based on the frequency. Using a parametric EQ to simulate a shelf filter shape isn't exactly ideal. Is there a way to do a shelf filter shape phase adjustment in rePhase?
Old 30th April 2017, 04:09 PM   #2024
BYRTT is offline BYRTT  Denmark
BYRTT's Avatar
Originally Posted by bcodemz View Post
.....Is there a way to do a shelf filter shape phase adjustment in rePhase?
Suggest try start on "Paragraphic Gain EQ" tab and make those shelf filters data you think about which will create IIR filter phase shift, now go to "Paragraphic Phase EQ" tab and use whatever it takes to flatten phase shift again and maybe it helps using example three banks or more where one is set Q=1 next is Q=2 on then Q=4, in the end when phase is corrected flat then disable those IIR shelf filters and you end up have the phase shift only. Into these two tabs there is also convenient help commands in the "Tools" and "Preset" buttons.
Old 30th April 2017, 06:05 PM   #2025
Phase shelf filter: Is that a all pass filter? Never remember if allpass is lp or hp unity gain.
Old 30th April 2017, 07:11 PM   #2026
pos is offline pos  Europe
pos's Avatar
I'm trying to correct the phase issue of a rear firing woofer cancelling with the front woofer because of the difference in path length.
Hello
What you need in such a situation is simply delay and polarity switch
waveTracing | rePhase
Old 30th April 2017, 08:22 PM   #2027
Oh, isn't the woofers in the same box?
Old 30th April 2017, 08:41 PM   #2028
If it is two seperate boxes in a room, use a room simulator, as the room nodes will take over the responce. Rew and others have good simulators.
Old 30th April 2017, 09:28 PM   #2029
That's a really smart idea. I'm gonna try that.
Originally Posted by pos View Post
Hello
Wouldn't that turn my speaker into a cardioid in the woofer range?
Yes, woofers are in the same box.
Old 30th April 2017, 09:37 PM   #2030
mark100 is offline mark100  United States
Hi guys,
why would this need anything more than what Pos said, simple delay and polarity ?
I get you can move pattern around such as cardioid, but don't you just end up ultimately using the delay/polarity that gives you the pattern you want?
rePhase, a loudspeaker phase linearization, EQ and FIR filtering toolHide this!Advertise here!
FIR linear phase plugin for MiniDSP? diyjb01 miniDSP 17 9th June 2016 01:35 PM
FIR filter design tool for Loudspeaker magnitude equalization ttmusic Software Tools 3 24th May 2013 08:30 PM
FIR Filtering experiences Olombo PC Based 8 10th February 2013 03:45 PM
AVX based FIR VST, crossover / EQ / DRC and delay KOON3876 PC Based 97 26th November 2012 07:18 AM
Phase EQ using FIR filters Grasso Multi-Way 2 2nd July 2003 10:37 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
