Ultimate Open Baffle Gallery
Later i built second, even more compact version of the 4way open baffle setup. Bass is dipole with two 15" woofers in tandem. Rest is the same, as is crossover. I have posted these before, just to show small or no baffle.
I use biamping with plate amp active plus 31band ultracurve, so making bass flat is no issue.
OK, here's the same setup as modeled in Edge above (see post #4657). This time, in Basta!, using driver parameters, and with a passive crossover. @adason I adjusted the vertical scale to approx 25dB/decade, in line with IEC recommendations. (I may have made the baffle slightly wider this time, bringing the problem frequency a touch lower.)
Reactions: Juhazi
Dipole cancellation is compensated in active crossover by selecting different crossover frequency for upper and lower path. Say your upper path is 180 Hz (i use 150Hz), but for low path you select 100, or lower, even 80 Hz. Then you simply increase the level in lower path to compensate. Decreasing dipole cancellation is opposite to eq, thus helping to flatten it out. To some extent, offcourse. Nothing is perfect.
Reactions: gpapag
By the way, Edge gets jammed on my laptop if I use 3-digit Speaker source density. Something like 20-30 for both is good enough.
Edge uses flat pistonic driver, so very high resolution is pointless, because driver specific problems overrule above 1-2 kHz anyway
Reactions: ianbo
My mostly folded front open baffle speakers. The stereo pair started out as 12" single drivers, placed for easy active eq to flatten a little but mostly suit my taste. Soon after adding helper tweeter attempts, I went full multiway, with placement and crossover points chosen for low excursion and peaks if they weren't dipped with.the crossover.
I didn't at first use a rear tweeter, but it's paralleled with the front one to share the load, which allows a strain free sounding lower output to meet the mid at-6db at 1800 hz first order.
The old Sansui 12" have new lighter surrounds, which further lower their made for sealed cabinets Q.
I'd tried these with a couple kinds of 2nd order filters with closer filter knees, but like the sound and lower parts count of a first order crossover, ranging between -5 and -9db crossover points.
I do use a bass panel for movies and cable programming, but there's enough to not use feel like I need it for my 2 channel system for music streaming, or records.
Reactions: MalVeauX and Gill.T
@ianbo What did the crossover look like used in this simulation? 🙂
