LT4320 based active rectifier
1. LT4320 CRC PSU PCB
namghiwook x 4 nos.-paid up
birdbox x 15nos.-shipped
kirks x 4 nos.-shipped*
ZOLTAR x 4 nos. -shipped*
baswamin x 2 nos-shipped*
jpaudio x 2 nos- shipped*
danbmellow x 4-shipped
arthur x 10 nos. - shipped
remaining=25
2. LT4320 THT RECTIFIER
swak x 10 pairs- shipped
remaining=0
3. LT4320 SMD RECTIFIER
birdbox x 20 pairs- shipped
shattered_dreamX PAIRS-SHIPPED
remaining=30 pairs
note: * indicates, these orders were shipped already out of the 70 qty stock.
prasi,
I cannot find three pronged FASTONs as are pictured. I cannot find anything that would mount to the inputs and outputs.
Can you point me towards what you intend to be used, please?
I have nothing against simply soldering the wires to the boards unless there is a reason to not do this.
Thanks and take care,
@wcwc,
I’ve used the Molex Rt. Angle header pins as Prasi mentioned, they require a bit of customization in order to fit.
But also have used cut-offs from diodes (ex. 1N4007), thicker lead than resistor cut-offs for better strength.
Either method requires direct soldering to the psu board, would never use sockets here for “pullable card” type of install.
Reactions: ricyuyc
prasi,
I was confused by the drawing. I see there are not three legs.
I ended up getting ones with the screw and figured I would remove two of the four legs. There is enough room on the board for this to work fine.
Never liked FASTON - but I do like the ability to remove connectors - I cannot remember the part number so I cannot post an illustration.
Hi Prasi and anyone with thoughts,
I am late to the scene, but eager to try this,
Still reading through the thread, but will the LT4320 work with this power supply for my phono preamp?
OR will I have to follow post #1057
Using the Talema Toroidal and want to replace the two main D1 & D2 KBL 406 rectifiers
I will eliminate the snubbers.
What is the best MOSFET recommendation?
Thanks in advance for your advice,
