10 pairs of smd (20 pcbs) will cost 25 usd and 2 of the crc will cost 13 usd. shipping and paypal extra. approx 9-10 usdHmmm how can I order ?
Would take 10 of the smd rectifiers and perhaps 2 of the psus... What was the price of those psus ?
Hmmm since I got 8 of your standard psu pcbs and the difference is not that big I think I need the 10 pairs of the rectifier...
Best regards,
Eddy
Best regards,
Eddy
The IC and the FETs do not ring themselves. Inductance and capacitance in the transformer can form resonant circuits that ring when the FET, which acts like a clapper in a bell, smacks the xfmr a good one.But does LT4320+FETs rings like a regular diodes?
1. LT4320 CRC PSU PCB
namghiwook x 4 nos.-paid up
birdbox x 15nos.-shipped
kirks x 4 nos.-shipped*
ZOLTAR x 4 nos. -shipped*
baswamin x 2 nos-shipped*
jpaudio x 2 nos- shipped*
danbmellow x 4-shipped
arthur x 10 nos. - shipped
remaining=25
2. LT4320 THT RECTIFIER
swak x 10 pairs- shipped
remaining=0
3. LT4320 SMD RECTIFIER
birdbox x 20 pairs- shipped
shattered_dreamX PAIRS-SHIPPED
remaining=30 pairs
note: * indicates, these orders were shipped already out of the 70 qty stock.
remaining=25
remaining=0
remaining=30 pairs
prasi,
I cannot find three pronged FASTONs as are pictured. I cannot find anything that would mount to the inputs and outputs.
Can you point me towards what you intend to be used, please?
I have nothing against simply soldering the wires to the boards unless there is a reason to not do this.
Thanks and take care,
Hi Rick,
fastons bring flexibility in wiring.
i intended following fastons
https://www.mouser.in/ProductDetail/TE-Connectivity-AMP/1742188-1?qs=WeHYKPpr/ZjkIm9M/HMLJg==
its corresponding mating part is
https://www.mouser.in/ProductDetail/TE-Connectivity-AMP/3-350820-2?qs=PYuwUcyJEnGYtcefCeGluw==
Does anyone know the Pin size for the header or part number to connect the SMD Rectifier to the compact PSU?
something like this? 538-22-28-6160... the pcb holes are 5.08 mm spaced, so you can cut off alternate pins.
However you could also use 18AWG enamaled wire and bend it in 90 degree and solder.
@wcwc,
I’ve used the Molex Rt. Angle header pins as Prasi mentioned, they require a bit of customization in order to fit.
But also have used cut-offs from diodes (ex. 1N4007), thicker lead than resistor cut-offs for better strength.
Either method requires direct soldering to the psu board, would never use sockets here for “pullable card” type of install.
PhopsonNY x 4
PhopsonNY x 10 pairs
Paypal is in PM
PhopsonNY x 4
Paypal is in PM
prasi,
I was confused by the drawing. I see there are not three legs.
I ended up getting ones with the screw and figured I would remove two of the four legs. There is enough room on the board for this to work fine.
Never liked FASTON - but I do like the ability to remove connectors - I cannot remember the part number so I cannot post an illustration.
I will probably use some enameled wire since I have extra from some inductors I built. Thanks.
Hi Prasi and anyone with thoughts,
I am late to the scene, but eager to try this,
Still reading through the thread, but will the LT4320 work with this power supply for my phono preamp?
OR will I have to follow post #1057
Using the Talema Toroidal and want to replace the two main D1 & D2 KBL 406 rectifiers
I will eliminate the snubbers.
What is the best MOSFET recommendation?
Thanks in advance for your advice,
Hi Prasi,
I'd like to order 10 x Smd rectifier and 4 x crc with shipping to the UK, could you Pm me price and payment details?
Chris
Chris
Hi Chris,
I have last 9 pairs of SMD rectifiers and 10 nos. CRC PSU PCB.
price as mentioned elsewhere in thread, 2.5 USD per pair for SMD and 6.5 USD for CRC PSU PCB.
I have sent you a PM .
Hello All,
Now I only have 6 nos. LT4320 CRC PSU PCBs.
If there is still interest and requirements, I could order another batch of SMD and THT rectifiers and CRC PCBs, but would take about a month.
regards
Prasi
regards
Prasi
- Group Buys
- LT4320 based active rectifier
