Did you send any message yet? I not got any.
I haven't got any messages, yet, too. I think he may need more time
Please be patient.
I'm currently dealing with few PCB manufacturers.
I do not want to start collecting money without been sure that quality of boards is top.
Tibi
Have added your name to the list.
Please note that in case you take only PCB, you should be able to flash atmel microcontroller by yourself. This was documented here http://vicol-audio.ro/img/volume-controller/VA_r-2r_volume-controller_firmware.pdf
Tibi
Tibi
Cheers Tibi, that's very much appreciated. I've not used this device before, but have flashed other devices in the past.
u r welcome !
Than shouldn't be a problem for you. Anyhow the document I wrote is, hopefully, explanatory enough.
Tibi
I am late to the game as well. If not too late, would appreciate being in for 2 of the PCBs if possible for a balanced setup.
Thanks,
ym
Hi ym,
For a balanced setup you'll need 4 complete PCB's.
Tibi
Just seen this group buy, I assume its to late to get a board and controller (opt 2)?
You are on the list. Thanks
Tibi
Myint67 & Apogee
You have been added to the GB list. Please check and confirm.
https://docs.google.com/spreadsheets/d/1_kUabT9rPURKtaWrDb4jncI6iFLUFfFIIAyoHXEqhpQ/edit#gid=0
Tibi
Tibi
- Group Buys
- GB for R-2R Volume Controller with 4 inputs
