GB for R-2R Volume Controller with 4 inputs
VC boards are ready and on the way to Romania. I expect to get them in the next days.
Paypal payment is still delayed due new paypal regulations imposed by EU. Even I have provided all company documents, lifting receiving limit looks to be a time consuming process.
Sorry for this delay.
Regards,
Tibi
Hello Tibi
I subscribed to this GB with two bare PCBs. I intended to build the LED version with some kind of interface to drive 7 segments VFD display. That’s the reason I didn't subscribe the pre-programmed Atmega.
When I look to schematic on post 46, I realize that the LED section is missing, so the main question is:
Does this PCB support the LED version?
Best Regards
Hello Tibi
Best Regards
Hello,
PCB can support 2 digit LED display, but we'll not provide a better firmware than http://vicol-audio.ro/img/volume-controller/ATM16_SHUNT_R_2R_LED.zip
You must know that is a big difference between LCD and LED firmware. LCD is far better in term of operation and functionality.
Regards,
Tibi
New boards are ready.
Time to proceed with this GB. 🙂
Thanks for patience !
Regards,
Tibi
Tibi,
If you happen to have two additional bare PC boards, I'd love to add them to my order. If not, no problem. However, I figured it couldn't hurt to ask.
It would revise my order to 3 bare + 1 with microcontroller.
I was just looking again at the spreadsheet and thought "might as well ask to see if I could get the parts for 7 channels while I'm doing it."
Again, no problem if you don't have enough. I completely understand as I didn't think about it when I ordered.
Either way, I'm very excited!
Thanks,
Steve
Great!
What is the maximum number of boards the microcontroller is able to handle? The reason I'm asking is would it be possible to configure the controller for balanced for the front two channels and single-ended for the center, sides, rear and sub? In other words, 2 balanced and 6 single ended channels - so 5 boards total. Can the controller handle this?
Great!
As you can see from my first post, we made for a recording studio this controller with 12 channels. This is equivalent to 6 stereo channels or 3 balanced.
To answer your question, with a dedicated firmware and few extra transistors it is possible to drive 5 boards.
Regards,
Tibi
Tibi,
Thank you for pointing me back to your original post. I had forgotten that it showed stacking for multiple channels. Perfect! 🙂
What is required for the firmware change? How do I specify this and is there an additional charge for this?
THANK YOU for your help!
Steve
Tibi,
Steve
Your microcontroller will be programmed for 2balanced+1stereo. For this you'll need one more board and custom firmware option.
Regards,
Tibi
