Full Range Speaker Photo Gallery
Surprisingly or not, with the Minmeh I can hear the comb-filtering pattern dave has often posted. From ~3m away slightly off-axis ~0.4m, ear angled for maximum acuity, the sweet spots are ~10cm apart shifting (head) horizontally, or ~20cm forward/back. At these nodes the music is more open and realistic, presumably due to very high frequency present; away sounds a (very) little duller, less micro-dynamic contrast. I first noticed this when, each time I thought it sounded A+, with a head-sway it no longer was.
How to reduce horn/mouth/throat diffraction combing? VHF should be throat?
Happy to report issue resolved with Art's diagnosis:
Pretty good now, ~35° horizontal coverage of flat FR to 12khz that I could hear (Faital HF108 exit angle being 31°). My cost was ahem $220 for eight used drivers (CD, Faital-inside, 12" Aura) plus significantly more than that for the Jantzen aircores and silver zcaps which I reuse for diy-of-the-day.
Update: MEH vs offset TMM.
@mayhem13 suggested MTM so I thought I would take a few minutes to rearrange the Faital drivers and listen to both music & tone-sweep. Of course it turned into a weekend project....
First I determined the (hornless) HF108 faceplate and LDA-401 grille time-offset to be ~2cm (without XO) and tweaked MTM (beware magnetic attraction!) to work well enough but only by reversing polarity, achieving phase-alignment (by ear) while sacrificing time-alignment by 1cm offset. This imaged better than the MEH but I was not completely satisfied. (Note: by carefully poking a bent-paperclip through the LDA-401 grille I measured 1.25cm to the driver surround.)
Figuring 1khz 1/4WL 8.5cm, I rearranged the drivers into T/MM pyramid (CtoC ~12.5cm) and tried crossing low. Long story short, I didn't like 2nd-order phase/imaging (2cm+12R->4.7uF/0.3mH, 0.3mH/8.6uF). Back to 1st-order with a 2-5khz broad notch filter just like the MEH but tweaked HP/LP to match phase as much as possible (2cm+14R->4.7uF->3.9uF||0.62mH, 0.3mH).
Importantly, I learned the hard way that the 31° exit-angle HF108 would spread >10khz very high frequency more broadly than a hard dome tweeter and the HF/VHF reflected strongly off its faceplate to mess up phase and FR. I made a soft absorber/waveguide out of folded antistatic wipe (wool worked better but I didn't want to hole old scarfie). The mess of XO bits chained with electrician's twist caps allowed me to test different value combinations just by moving alligator clips. Finger tone-sweep and loudness-comp up to three frequencies using APP Frequency Sound Generator; listen to test music for faint transcient detail and size/depth specificity (just 1ch, ear on-axis angled ~30° lined up using 11khz tone), ideally well-focused "beyond the wall".
I think, with 9mH->12" Aura over a tall closed tube this combo could be a candidate for A+/A+/A+.
