10F/8424 & RS225-8 FAST / WAW Ref Monitor
Annoyingly have done my woofer rebates a little too tight...bugger!
Spent a good while trying to get a good finish on the baffles which I have now done. Using a gloss roller with water based emulsion. It marks easily though so I may wax it.
Now how to relieve the cutouts a bit.!
Very beautiful work! Try a dremel tool to make the rebate wider. This has happened to me before. You did not do a test for before paint? Or the paint made it too tight?
Yeah, currently it's a bit smaller (18.65in^2 vs 21.25in^2 on the original. I'm going to play around with offsets to make the volume/surface area the same. I believe if the volumes/area is the same, then the rounded corners should benefit vent noise to a small degree if I'm understanding this correctly.
Having messed around with the numbers super quickly, I should be able to get it to 21.15in^2 by increasing the width. This would also mean inlaying the stacked vent pieces into the sides which would far more accurate construction.
Alternatively, increasing the height of my vent from 2.5" to 2.87" would result in 21.25in^2 vent area. Would increasing the height have much effect?
The TL simulations are for the plan as drawn. If you modify it by adding a step change to the terminus and change terminus (vent) cross section - it will not perform as designed. That is the most sensitive spot to change things up too. If you change a cm here or there where it is big at the other end of the TL, no big deal. At the exist is where it is narrowest and here is where geometric effects are magnified. My main concern is the abrupt step down to an oval that’s smaller than cross section of TL up to that point. It’s been gradually tapering down at each corner where the area actually increases. A sudden constriction will be seen by the aero acoustics as the new (shorter) TL length boundary condition. The 1/4wave will anchor to that lip. The oval vent now mass loads the TL. So it’s no longer a gradual taper TL as designed. The vent velocities of the original design are very low, you don’t really need to have large round overs to reduce wind noise. There is none. That is one of the things I design for - vent velocities well below 15 m/s at max SPL. That’s not going to be an issue in this speaker.
Thanks X...they were a snug fit and I tried to avoid paint in the recessed but the slightest amount and it is too tight. I could maybe draw them in with the screws but didn't like that idea! I'm getting there with good old fashioned sand paper.!
Hi Xrk971,
I'm lurking the 1st slope passive XO you made but for a sb23NBAC-8 instead the RS25 and the 10F/8424G (I purchased for the foam horn project sme times ago).
I see the cut-off is around 320 hz. I have a noob question please; Have you tried a higher cut-off, i.e. around 600hz to 700 hz with a BW6 as well ?
many thanks, I'm a bit hesitating between a 12/18 lmost perfect transcient pssive and a first slope... 320 hz 6db on the paper seems to me too close to the low end of the 10F due to the low slope. I have no doubt it sounds good but would like to know if you tried higher cut-off and liked what you heard ? (the bafle step is maybe also easier to rule with something near 700/800 hz, though I'm building the box yet so haven't zrd yet for Xsim
many thanks if an opinion about that (fact is I also hesitate with a tweeter above the 10F but I'm constructing à l Haberth in order to change easily the project...)
cheers.
Not sure what you are referring to? Can you post link to the specific post? I never made a XO for SB23 woofer - I recycled old passive one for RS225 to see what would happen and used it in open baffle only.
Thanks X
My bad, I believed your 4 mH coil on the dayton and the 82 uF parralel to the 10F gave an electrical 1st order 320 hz cut off. I certainly missed something...Maybe the Dayton is not 8 ohms but 4 ohms unit...or I have not simulated with the acoustic center of the drivers...I just took the values of your passive filtet and fill in the Vcap on line filter simulator...
I’m sorry, are we talking about the same schematic? Here is the final speaker xo that is being used. 82uF in parallel with 10F??? I think it is 2.2uF in parallel.
656203d1515700364-10f-8424-rs225-8-fast-ref-monitor-xrk971-10f-rs225-fast-schematic-jpg
Predicted XO function:
656204d1515700364-10f-8424-rs225-8-fast-ref-monitor-xrk971-10f-rs225-fast-freq-jpg
Many thanks, yes this one, I did not see the graph, my bad... so a near 850 hz XO ?
That's the 4 mH that was puzzling me as I use on line filter page, they say something 320 hz ! and te 61 uF in serie with the 10F as well ! So I miss something in the understanding of it !
C1 + R3 is flatening the impedance ?
I'm going to try this with the 10F 8424GO but for the 22 cm, it will be a SB23NBAC45-8 instead the Dayton... I will report on howw it sounds. Default of the SB23 is a little high odd order after 500 hz but h3 is still around 35/40 db below the fundumental...
So you like better that filter vs an almost transcient with higher slope ?
In this particular case, the very shallow XO and nice behavior of both drivers works very well. Yes, C1+R3 flattens impedance.
If you want to try a higher order XO but still keep transient perfect, there is a way to do a Harsch passive XO that uses 4th on woofer (2nd order electrical combined with natural roll off at woofer top end) and 2nd order on tweeter. Circa 3.5kHz yields an almost transient perfect response plus steeper filter. I did this with Purifi PTT6.5 and dome tweeter in a waveguide. It sounds exceptional.
Simple Passive Harsch XO Using PTT6.5 and RS28F in a Waveguide
Specifically, this post:
XO:
868139d1597513796-simple-passive-harsch-xo-using-ptt6-5-rs28f-waveguide-ptt6-5-rs28f-wg300-xo-schematic-jpg
Here is frequency response:
868142d1597513796-simple-passive-harsch-xo-using-ptt6-5-rs28f-waveguide-ptt6-5-rs28f-wg300-tl-xo-freq-2vrms-0-5m-jpg
Here is step response:
868144d1597513796-simple-passive-harsch-xo-using-ptt6-5-rs28f-waveguide-ptt6-5-rs28f-wg300-tl-xo-step-2vrms-0-5m-jpg
Thanks for the tip X, if I go 3 ways I will try it, though I have no active set-up, so staying passive can cost me a little monney...
Ok, so I understood correctly, the passive above is a circa 320 hz passive first order elecrical XO, but the shallow overlap works well here with the Dayton... I will try it with the SB23NBAC if I sucseed to deal with the baffle step as my cabinet will be not the same size.
Thanks again for the tips and input... ah I just need to find a compass router jig here in Europe, have the drivers and chosed a ply cabinet cause of the wood looking whilr still have some foam I keeped from your horn project with the 10F ! Great little driver, I love it, neutral my ears says 🙂
cheers...
And some more progress on my build. Have wasted a lot of time on paint finishes which is annoying. I have also made some additional rear panels which will be sort of cld as I will stick them on with butyl. These enclosures like many 1970s and 80s speakers have a recess in the back which will take a layer of butyl and 6mm MDf quite nicely. And so will stiffen up the rear panel without loosing me any interior volume.
Traffic cone is mounted and sealed....I think.! Will test with the woofer cone press test.
I'm hoping my gasket for baffle sealing won't fully compress before sealing the air to allow a degree of isolation from the baffle into the box.
Other than trying to find room for the crossover in there I am working my way through. Would like them done for Christmas but it isnlooking doubtful!
