I have an old stock of Soviet precision metal film resistors S2-29V that I use as a reference. Compared them to Dale's 5 ppm resistors and there was no difference in the measurement area. Statistics and various practices indicate that they are most likely linear, as far as I can currently measure.
But in general, each sample of any resistor and capacitor should be tested individually before it is used in critical locations.
IMHO those, as Demian wrote: Vishay doesn't even publish linearity info on the Bulk Metal resistors. https://foilresistors.com/docs/63140/var.pdf
In the old days there was the Alpha Core as also none inductive as in a black plastic block.
As mentioned:
At that, negligible capacitance/inductance of foil resistors (when compared to wirewound resistors) significantly reduces
probability of self-excitation or "ringing" of amplification circuit.This is why Bulk Metal® foil resistors are such a good
choice for low-noise applications...
MELF resistor from Token Electronics as none inductive as RFM series
As mentioned:
Yes, in many cases.The better resistor is two resistors in series instead of one.
Also, by connecting four identical resistors in a series-parallel circuit instead of one and comparing the results, we can understand whether the resistor is linear or not.
One resistor ARG05FTC1502:
https://content33-foto.inbox.lv/albums/e/elterra/ResitorLinearityMeasurements/1R.jpg
Four ARG05FTC1502:
https://content33-foto.inbox.lv/albums/e/elterra/ResitorLinearityMeasurements/4R.jpg
hi excuse me Which model precisely ? thank you very muchmy $130 Juli@ does that good with much narrower noise skirt
here's one RMAA test: RightMark Audio Analyzer test : Juli@ loop
