Analog Delta-Sigma interpolation DAC
Thread Tools
Old 27th February 2021, 08:39 AM   #391
Hans Polak is offline Hans Polak  Netherlands
Hayk,
You could use this free filter sotware tool, to produce all kind of linear phase, minimum phase or whatever type of filter.
rePhase - Official Site - Free FIR filtering tool
Also look here where they managed to create a minimum phase filter with no pre ringing and nearly only one post wave, by stacking mininum phase filters with a distance of 2Khz.
Filter brewing for the Soekris R2R
Hans
Old 27th February 2021, 09:14 AM   #392
You should ask them for the details how they managed to use rePhase in combination with other programs to get this impulse response.
Hans
Old 27th February 2021, 10:47 AM   #393
U130421 is offline U130421  Antarctica
I could make very easily non pre ringing interpolator, the image rejection is a disaster.
no prering.JPGt
The frequency response of the impulse you show is ridiculous as mine, -25db at 30khz.
Old 27th February 2021, 11:13 AM   #394
The rephase software I have it downloaded in early January, brickwall linearphase 21khz, needs 16k samples,
Old 27th February 2021, 11:24 AM   #395
TNT is online now TNT  Sweden
With 4k taps you can do -185dB at 22.049 if you can accept say -0.1 dB down at 17k.
More distortion to the people! Timing . . . . is paramount.
Old 27th February 2021, 11:34 AM   #396
Attachment 926731t
Attachment 926732
True, but this was also the case with the T+A DAC test that I showed a number of postings ago #367.
But nevertheless, the reviewer preferred this filter.
So it’s a brickwall and somewhat cooler sound or a friendlier rol off of a minimal phase filter and “better” sound.
Hans
Old 27th February 2021, 11:48 AM   #397
A Blackman Harris window also looks attractive to use when playing with rePhase.
Very smooth with a large stopband supression.
Hans
Old 27th February 2021, 12:19 PM   #398
I have several of those nos USB stick soundcards that cost a $ or two. They all have harsh sound, I use to transform the Laptop into generator/scope.
I will study a more important aspect than the ringing, The transient 20khz. It needs three cycles to reach the steady state. I will see what I get with 60 samples.
The arrow shows the start of 20khz.
Old 27th February 2021, 02:18 PM   #399
More samples means more pre and post ring cycles.
Maybe you can try the added N+1 and N-1 trick to reduce ring cycles.
Hans
Old 28th February 2021, 05:06 AM   #400
The result with 60 samples is worst. How about reducing to 20?
Analog Delta-Sigma interpolation DACHide this!Advertise here!
Thread Tools
Philips tda1305 (hybrid multi-bit/bitstream DAC with interpolation) 1z2a3y Digital Line Level 37 22nd January 2021 12:02 AM
High quality parts used delta-sigma dac vs cheap parts used r2r ladder dac Esotar01 Digital Line Level 2 6th May 2016 12:50 AM
Question about DAC interpolation cuallito Digital Line Level 1 28th April 2011 11:11 PM
Delta-current linear-interpolation DAC wimms Digital Source 86 4th November 2004 02:05 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
