The New Hypex Fusion Plate amps
It is proven that some resistance in front of a tweeter may decrease distorsion. To many, this sounds less "fun".
This explains why I've been unable to enjoy some really expensive tower type speakers, the tweeters where distorting heavily much earlier than the mids. Even at relatively low levels.
I can accept some distortion in the bass region, just sounds a bit "more".
Yes, I really think so.
It was the last time I went into one of those fancy hi-fi shops, and it's been at least 10 years since. I had a listening session planned and got to listen to a number of different speakers. Quite literally made me run away from several known brands and never return.
Edit:
Heavy distortion on several of the tweeters.
Has anyone used an amplifier module separately from DSP/dac? Is it possible to unscrew it and just use for a stereo amp? Is it an ordinary nc252mp module there or a special one with different gains/inputs, etc?
I did that exact thing with the lower powered version, and it works perfectly. Carefully study the application notes for the standalone amp module to ensure you connect the input cabling correctly.
You can find that in the FusionAmp firmware v1.42.zip file:
Firmware v1.42 release notes:
Firmware improvements (v1.42):
- DSP equalizer was single precision, changed to double precision
- NCAS500 and NCAS1000 added in the firmware, available in next release of HFD
1.42 still online..
Did you mean the file isn't listed but can be downloaded by direct link?
I don't see a link in the Downloads section:
