Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Thread Tools |
#71 |
Ok, i have tried with the original FDA24N50F... They stay cold... I will continue now..Thanks a lot Mario and Perry
2Ch. DSO, Multimeter, Hot Air Station, Soldering Irons, 12V Server Supply, L-C-R Tester, Component tester |
#72 |
Ok, install power diodes and the lowest you can battery voltage for the firts power up.
If i remember, gzpa10000spl HC allow the minimun battery voltage of 12v for the start-up then, it can go lower once it is turned on completely., under this point remain in protection. Other amps (same design but lower power) accept 11 or 10.5v. Dont forget, use only one fet per bank (fda24n50f or irfp460lc). This allow you to perform the first start up to see the class D operation for 3seconds for each stage, so you can extend the test time to 10 seconds, 20 seconds, so, install other fets and use a speaker to try to listen 10 second of music..... If all ok, install all, install the board in the chassis and clamp all to the heatsink. Now you can try to power the amp at full battery voltage (14,5v) and good current reserve. If the amp survive at this.......you can use in the car... ahahah
Two things save us in life: love and laugh. If you have one, that's fine. If you have both, you are invincible. ![]() |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
How to use a dual opamp separately as two single opamp | Sunsun22 | Parts | 14 | 21st May 2016 04:08 PM |
DWM 3640 Driver Board | bl4ckw1d0w | Car Audio | 26 | 18th May 2016 10:02 AM |
bypassing DIN-9pin on a Sanyo DWM-3500 noob help | camcam089 | Everything Else | 1 | 12th January 2015 08:38 AM |
DWM 3640 CL2 CL3 | bl4ckw1d0w | Car Audio | 2 | 3rd June 2014 12:09 AM |
Double woofer design - measure together or separately? | btntx | Multi-Way | 3 | 7th November 2013 12:51 AM |
New To Site? | Need Help? |
