Test class d dwm drive board separately
Thread Tools
Old 21st November 2020, 04:17 PM   #11
Achim1409 is offline Achim1409  Germany
So, i tested, supplyed the +-5V, i have amplitude at pin 1 of the irs... But the IRS wont give out any signal. I have applied the 12V, but nothing happen.
On which pin at the irs i must have which voltage?
I expect:
Pin 3VSS: Ground
Pin 5 Com: Ground
Pin 7 VCC: +12V
PIN 11,12,13 VB, HO,VS :+12V?
2Ch. DSO, Multimeter, Hot Air Station, Soldering Irons,
12V Server Supply, L-C-R Tester, Component tester
Old 21st November 2020, 04:42 PM   #12
That's, how I have it connected.. The irs don't give a signal out.. The irs is OK.. I have dc +12 out at pin 11,12,13
Old 21st November 2020, 07:20 PM   #13
Perry Babin is offline Perry Babin  United States
11, 12 and 13 float. Their voltage needs to be measured with pin 11 as the reference.
Are you driving a signal into the board?
If so, do you have low-side drive?
Anyone who purchased the repair tutorial, email me (babin_perry@yahoo.com) if you want to download the latest version.
Old 21st November 2020, 07:23 PM   #14
I am driving a signal inside. I can measure the signal on pin 1 of the irs.. But no low side.. Only floating. Maybe there is something more wrong with the drive board.
Old 21st November 2020, 07:33 PM   #15
What is the voltage on pin 2 (referenced to the negative rail voltage, 3 and 5, whatever it is).
Old 21st November 2020, 07:33 PM   #16
Should I put the ground probe also on pin 11 to see the low side?
Old 21st November 2020, 07:36 PM   #17
Pin 2 is Zero volt. Ground Probe is at common ground
Old 21st November 2020, 07:40 PM   #18
If i use the ground on pin 11, i have 0V at 12,13...
Old 21st November 2020, 07:45 PM   #19
Maybe i made a mistake... I connected +12V from the LM7812 to Pin 18 of the Board, and Common ground to Pin 17. I think Pin 17 must be Negative rail...
Edit: Thats wrong...The irs burned directly
Old 21st November 2020, 08:08 PM   #20
I will think about it tomorrow again. I think I connected the 12v supply wrong..
Test class d dwm drive board separatelyHide this!Advertise here!
Thread Tools
How to use a dual opamp separately as two single opamp Sunsun22 Parts 14 21st May 2016 04:08 PM
DWM 3640 Driver Board bl4ckw1d0w Car Audio 26 18th May 2016 10:02 AM
bypassing DIN-9pin on a Sanyo DWM-3500 noob help camcam089 Everything Else 1 12th January 2015 08:38 AM
DWM 3640 CL2 CL3 bl4ckw1d0w Car Audio 2 3rd June 2014 12:09 AM
Double woofer design - measure together or separately? btntx Multi-Way 3 7th November 2013 12:51 AM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
