Not too shore. It arrived here like that but underneath each capacitor was clean and no corrosion on the pads. I set my scope to capacitance but when I go to check it doesn't show anything.
With no load I still have 22.35 DC volt. With 1.5 amp the amplifer is pullilng.. with a 4 ohms load(subwoofer coil) fans turn off. Amp only pulls .9 amps and voltage of speaker terminal goes to + 40mv. It's Chang's form .40 to .32 mv the coil is cold to the touch
- General Interest
- Car Audio
- Mtx ta92001 distorted output.
