JG´s Nobrainer and Nobrainer Discrete
The zeners and the diode form the voltage reference.... the setup aims for lowish impedance and temp compensation.
The transistor and the cap before the reg form a cap multiplier.... it works, I have used this for +- 15v in my cdp..... powering the output opamps....
But it is no cap multiplier 🙁 and I'm sure it will work as a 15V supply, the BC's change nothing about that!
The parallel zeners do not improve anything (they would if the matching was 100% (0% difference) but they are not 🙁 and even then ... mmm (doubts expressed 🙂)) Anyway long term thermal stability is not a problem (over periods of minutes even seconds). I would guess that modern day 317/337's are even more stable then the zener(s)/diode.
Found some D44 D45 power trannies in my stock... good... now I have an old Meridian 101 PSU that I would like to use in this project.... the output is +-35v so it is too much for the opamp.... can I use LM317 337 to feed the opamp at 18volts ?
When powering down, the capacitor is emptied through the BC's base-emitter diode, that is not advisable. To be a capacity multiplier you need some voltage drop between the BC's collector and base. On sudden large current demands, the output power is supplied through the BC's base-emitter diode (not good).
OK, good. The new National opamps have very good PSU rejection anyway.
I use a little trick i learned from Bonsai.
Use 22 Ohm resistors in series with PSU plus and minus and decouple with 220uF each.
I then use only one 0.1uF foil from plus to minus for HF decouple ( Self ).
That way you improve PSU rejection in the treble where PSSR of the opamp gets worse.
Here we have my first p2p draft.
Please comment on the component's layout and particularly on their pinout.
PS: Should the drivers be placed in contact with the heatsink ?
  • NB p2p.pdf
    NB p2p.pdf
