Ground their cases too.
Haven' t close the case yet. I plan to put some cooper foil around and ground it.
But I have no audible noise.
Merlin, I am tempted to try some teflon film and foil in the future. I use them in the RIAA part.
I used them in RIAA & interstage with superb resultsMerlin, I am tempted to try some teflon film and foil in the future. I use them in the RIAA part.
Search cap for RIAA!
BFC241644703 - 47n 2%
BFC241890017 - 47n 2%
FKP2-.015/63/2.5 - 15n 2.5%
FKP2-.015/100/2.5 - 15n 2.5%
MKP1837347161G 47n 1%
MKP1837315161G 15n 1%
OEMsTrade - Electronics Part Search
I have also as interstage 47nF teflon film & foil from USA
Merlin, do you know what the black stipe's are for? Input or output? I assume the later. Mark was not sure.
I used as outer foil for interstage & I don't headr any noise when touched by hand so is a good signal that the cap seems well shielded, yes Mark was not sure because I asked him 1st time I bought him the caps.
my new version for Salas pre-pre + MM RIAA (63db)
Based on the PDF for pre-pre+HMC=63dB?
This is the left channel of the new Salas 63db, according the pdf of post #6190.
On oscilloscope shows beautiful.
You put DIP switch loading I see. Clean assembly. Still big interstage caps...
- Analogue Source
- Simplistic NJFET RIAA
