Doug Self Preamp from Linear Audio #5
Thread Tools
Old 9th October 2020, 09:09 AM   #1571
Hicoco is online now Hicoco  France
tER i have I/O board with phono input, look in my signature. i don't know if that can help
Every DIYer need Balanced-Unbalanced Audio Input Selector Module
Old 11th October 2020, 09:06 PM   #1572
fvzeppelin is offline fvzeppelin  Germany
fvzeppelin's Avatar
Default Need help debugging
I am currently setting up my 2nd DS preamp. Unfortunately, I am facing a strange problem and I don't know where to start debugging:
Basically, everythng works fine, including the controls But when I turn up the Lo Gain, starting from somewhere above the center position, there is suddenly a loud hum on both channels until I turn back the Lo Gain
(Think I even crashed my 2 test speakers with it )
Ideas anyone?
Old 15th October 2020, 04:03 PM   #1573
tER299 is offline tER299  Netherlands
Thanks for the tip, it may very well! Do you, by any chance, have any FPD/DXF-files that'll fit the I/O board? And how would I go about connecting the I/O-part to the board? It's rather hard to tell from the images, but does the board switch between possible in puts (just like it would in the Doug Self I/O - output, see attachment) or are the RCA and XLR always active at the same time?
Old 16th October 2020, 12:37 PM   #1574
tER,
The board that will fit the best your need is 8 inputs with 4 RCA and 4 XLR ( separate from each other) with input RCA1 is reserved for phono input, the inputs switch between with the selector.
Yes i have FPD/DXF-files.
The inputs and ouputs connection to Dself preamp could be done easly from the HDR VERT DOUBLE 20P to the I/O board with the 5-pin Molex KK
The bad news is i am out of stock actualy of this board, i will need 2 weeks to get those, please PM if interested.
File Type: jpg PCB I_O PREAMP 8 INPUT connector version XLR:RCA.jpg (696.4 KB, 202 views)
File Type: pdf PCB I_O PREAMP 8 INPUT connector version XLR:RCA.pdf (409.1 KB, 39 views)
Old 20th October 2020, 09:05 PM   #1575
I updated and redesigned the 8 input Board (340mm x 66mm)to be able to use the same ribbon Cable who is connected to the Dself Preamp board with a new 20p connector. That is 4 Unbalanced RCA and 4 Balanced XLR separate Input.
File Type: jpg PCB- I-O CONNECTION BOARD 8 INPUT Version 2-XLR RCA.jpg (413.7 KB, 165 views)
File Type: pdf PCB- I-O CONNECTION BOARD 8 INPUT Version 2-XLR RCA.pdf (478.0 KB, 21 views)
Old 21st October 2020, 05:58 PM   #1576
Rick G is offline Rick G  United States
Is this V2 available on your site for purchase?
Also, do you have a template avail as a drilling setup for this i/o board?
Rick
Old 21st October 2020, 08:37 PM   #1577
Not yet, i have to send the file for production to the board house, and yes i have the drilling template for the rear panel.
File Type: jpg PCB-I-O-CONNECTION-BOARD-VERSION-2-XLR:RCA Dimensions.jpg (837.6 KB, 126 views)
Old 21st October 2020, 09:57 PM   #1578
OK.Thank You.Am interested when available.
Rick
Old 21st October 2020, 10:30 PM   #1579
diyralf is offline diyralf
diyralf's Avatar
Without being negative: I miss the RFI filters on the board.
Old 29th November 2020, 05:26 PM   #1580
Carl_Huff is offline Carl_Huff  United States
Hello all,
Watching this thread I wonder if builders would be interested in a nice graphic display showing input and what device has been assigned to that input? What I am envisioning could be a simple module that the existing IO PCB would simply plug into. The IO would be switched by the new module.
If the answer is ‘yes’, there is an interest, I then must ask the question should it be a simple $3 chip driving a graphic module or do we go all out and use a BBB (Beagle Bone Black) computer and explore the world of USB DACs and music servers. We could do an internet lookup and display a graphic and details of the music playing. Using a BBB would open new doors for us to experiment in.
Please keep in mind I only toying with the beginnings. So is there interest? If the answer is “yes” what direction would you prefer? A simple display or an all out embedded audio appliance?
Best Regards,
Carl Huff
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Thread Tools
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 07:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 10:16 PM
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 9 26th September 2013 01:11 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 11:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 01:02 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
