Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#1561 |
I believe the DIYAudio store can do the panel customizations using the FPD files. No need to engage a separate vendor. In addition, the DIYAudio store offers re-anodization after milling, which FPE here in the USA does not offer.
#1562 | |
![]() Quote:
#1563 |
Why is Carl Huff's pre-amp implementation not sufficient for you needs?
There was also the Elektor Pre-amplifier 2012. |
#1564 |
Thanks DM55.
I'll try to get some of my inbox freed up |
#1565 |
DM55
Inbox empty. Fire away |
#1566 |
I did not know that the store did machining and Infill. They use .FPD's. Are they just sending on to Front Panel. How about costs?
#1567 |
Finally about to start this! Couple questions-
1) Digikey is out of the Amgis L01-6354 until December. Alternatives? Antek AN-0218 - 25VA? 2) Input - I only need one input (RCA for phono). Could I remove the IO and wire directly to the main PCB? That seems to leave out the 3 second delay on the IO board. Not a big deal to leave the IO board in. 3)Another idea is to include a phono (Bugle2) in the case and run it directly to the main PCB. I will primarily be using this with an Aleph J, so it would be nice to have phono-preamp-amp connection with the ability to bypass the tone controls. Might be unnecessarily restrictive, but I can always change it later. Please feel free to PM me on questions 2&3 since they are specific to my build and I don't want to clutter up the thread. Any general insight or considerations would be extremely helpful. Still learning on this. |
#1568 | |
#1569 | |
You can wire the phonostage directly to it
https://www.vzaudio.com/ Last edited by jwilhelm; 29th September 2020 at 10:42 PM. |
#1570 |
Would it be possible to get the I/O board separately? I've been struggling with seemingly differing dimensions, and have now lifted some pads.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Doug Self Elektor phono preamp: SA1085 substitute? | tcpip | Analogue Source | 12 | Yesterday 07:43 AM |
Doug Self's New Preamp Construction and Pictures | redjr | Analogue Source | 190 | 30th May 2018 06:34 AM |
What does preamp PSU oscillation look like for linear regulators? | shredhead | Power Supplies | 59 | 28th March 2015 09:16 PM |
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB | mclsound | Swap Meet | 7 | 26th July 2013 10:10 AM |
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) | nickds1 | Solid State | 4 | 9th November 2006 12:02 PM |
New To Site? | Need Help? |
