Home | Forums | Rules | Articles | diyAudio Store | Blogs | Gallery | Wiki | Register | Donations | FAQ | Calendar | Mark Forums Read |
Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Thread Tools |
#1541 |
i go trough the scematic and look over my psb cant find any fault.
i took some pictures. if someone has any ideas what i can do i would be happy. ps its the left channal that is low volume, i turn the balance all the way to left to get equal signal...but i cant use tone controll because off the whining noise. ![]()
Tomi |
#1542 |
Tomi |
#1543 |
Does it make any difference if you flip the tone bypass switch?
https://www.vzaudio.com/ |
#1544 |
Dont want to intrude on trouble shooting issues but this is the right place to post. Maybe I can help on TS also. Finally got around to putting into proper case. If anyone needs FPD files that work I can supply. I offboarded volume pot and changed lettering from Carls files. Kind of a throwback to the 1U pres from the 80's and 90's
#1545 |
Kind of small for any detail. let me know if anyone wants to see more detail.
#1546 |
Tommi,
BTW did you build up your own ribbon cables? I had the most issues with cabling getting PIN for PIN matchup and the selector switch with the ribbon connector header pin 1 pinout. Look that over carefully took me 2-3 times to get everything just right. |
#1547 |
Hi
Yes its difference when i move The tone contrll, The biggest difference its The treble range its start to feed... Like feedback from a mic to loudspeaker. I buy standard ribbon cable ready with contacts
Tomi |
#1548 |
So are you saying that with the tone control switch in it has feedback and when it is out it doesn't?? Important to completely understand the symptoms
#1549 |
Yes IF I turn it off or turn down to lowest on The treble scale its get less and disapear.
But with out tone contrll its sounds good Just That The left channal its half The output
Tomi |
#1550 |
To try to narrow down where the issue is, remove A4 and see if the volume is louder with the tone control switch in bypass. Do the same with A3 removed.
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Doug Self Elektor phono preamp: SA1085 substitute? | tcpip | Analogue Source | 10 | 30th March 2021 06:09 PM |
Doug Self's New Preamp Construction and Pictures | redjr | Analogue Source | 190 | 30th May 2018 06:34 AM |
What does preamp PSU oscillation look like for linear regulators? | shredhead | Power Supplies | 59 | 28th March 2015 09:16 PM |
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB | mclsound | Swap Meet | 7 | 26th July 2013 10:10 AM |
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) | nickds1 | Solid State | 4 | 9th November 2006 12:02 PM |
New To Site? | Need Help? |
