Doug Self Preamp from Linear Audio #5
Thread Tools
Old 7th October 2018, 05:32 AM   #1201
Hicoco is offline Hicoco  France
Originally Posted by Carl_Huff View Post
Yup, that's it minus the Lorlin front panel switch. Mouser stocks them now.
Thank Carl, but will you ship the pots from Tayda with the PCB kit?
Old 7th October 2018, 05:53 AM   #1202
Carl_Huff is offline Carl_Huff  United States
I do not supply the pots. Buying the pots has been left up to the builder.
Is buying those pots a problem for you?
Best Regards,
Carl Huff
Old 7th October 2018, 06:08 AM   #1203
I do not supply the pots. Buying the pots has been left up to the customer.
No I am asking because they were part of the kit in the beginning, I am doing my BOM list right now and i am checking what do i have new to buy (not in my inventory), thanks
Old 7th October 2018, 12:11 PM   #1204
batteryman is offline batteryman  United Kingdom
Default Omeg green pots now available in the UK
At last my order of 4k7 pots arrived so can get on with the build
CPC still have 90 in stock.
https://cpc.farnell.com/omeg/pc2g16e...4k7/dp/RE04429
Old 7th October 2018, 08:42 PM   #1205
Originally Posted by DoubleIPA View Post
Thanks!
I'm finding several parts, like the aluminum electrolytic capacitors (UES1V101MPM), to be out of stock at mouser and digikey. I found a few on arrow.com, but not all of them and it seems like many are back-ordered until Feb 2019. Looks like I'll be waiting a while.
look at TME
They dispatch in New Zealand
Old 10th October 2018, 01:33 PM   #1206
Freecrowder is offline Freecrowder  United States
Thanks HADIHF for the I/O schematic. Very Nice. Needed for troubleshooting. Can anyone take a quick measurement of the output of the 12v reg on their boards and report your voltage? Mine measures 17vout with 19vdc input. I expect the 19 in that is what the power supply is. I checked for orientation and then replaced it but still the same. Everything works okay but it's just bugging me.
BTW build your own cables everything can be purchased from Amazon. Much cheaper in the long run.
Old 10th October 2018, 02:45 PM   #1207
manamanam is offline manamanam  Greece
Reg output should be 12VDC and input should be 17VDC
Old 10th October 2018, 03:17 PM   #1208
paulf is offline paulf  United Kingdom
Hi Freecrowder - some reports of regulator oscillation in thread #1058 and onwards. This results in the o/p voltage sitting ~2 V below the i/p voltage, which sounds like what you are seeing. Suggested fixes were additional capacitance - one user suggested soldering SMD caps directly on the regulator pins, on the underside of the board.
Old 11th October 2018, 03:08 PM   #1209
Excellent info paulf! Iv'e never experienced an oscillating 3 terminal reg before. I'll reference the data sheet for solutions.
Old 12th October 2018, 02:46 PM   #1210
Just an update. A 22uF tantalum directly across output to common solved the problem. I also notice that both pass transistors on the DC PS run much cooler now. You couldn't hold your fingers on them for more than 5 seconds before.
Doug Self Preamp from Linear Audio #5Hide this!Advertise here!
Thread Tools
Doug Self Elektor phono preamp: SA1085 substitute? tcpip Analogue Source 12 19th April 2021 07:43 AM
Doug Self's New Preamp Construction and Pictures redjr Analogue Source 190 30th May 2018 06:34 AM
What does preamp PSU oscillation look like for linear regulators? shredhead Power Supplies 59 28th March 2015 09:16 PM
OLDSCHOOL CAR AUDIO-ORION/US AMPS/LINEAR POWER/PLANET AUDIO TUBES NIB mclsound Swap Meet 7 26th July 2013 10:10 AM
4th Ed. of Audio Power Amplifier Design Handbook (Doug Self) nickds1 Solid State 4 9th November 2006 12:02 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Copyright ©1999-2021 diyAudio
