The Kuartlotron - keantoken's simple error-correction superbuffer
Old 22nd September 2016, 02:07 AM   #701
Destroyer OS is offline Destroyer OS  United States
Destroyer OS's Avatar
RCruz, I just noticed you didn't use the TL431... I guess I'm just reading my own experience over again!
Old 22nd September 2016, 10:38 PM   #702
BenY is offline BenY
Originally Posted by keantoken View Post
R9 is the DC trim. You may be sending ~1uA of DC through your cart (if I assume correctly that is what you're doing). Either that or your BC560 has ~250Hfe. Or possibly it is running at double it's intended current (could happen if you don't use Fairchild transistors). To adjust R9 all you need is a DMM.
Why is it recommended to use the Fairchild transistors? What is wrong with the ON Semi ones?
Old 22nd September 2016, 11:30 PM   #703
keantoken is offline keantoken  United States
keantoken's Avatar
They are out of production for one. Also the Vbe is different, so they require some adjustments. In listening tests the Fairchild transistors seemed to work better.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 24th September 2016, 05:51 PM   #704
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Will do soon
RC
Old 25th September 2016, 12:05 PM   #705
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
Here is my buffer from Keantoken the board is from Project16
I use unmatched ON Semi transistors , my offset is 0.1-0.2 mv.
i put total 3,7ΜΩ resistors for R12 .
i use 10uf cap before the buffer and 10ΚΩ and 50ΚΩ pot.Super quiet...
Titan 2000 ,Cressendo Millenium 2000, P3A ,VSSA ΤΟ3 ,B1 Buffer ,Golmund Mimesis 9.2 Clone , Dispre 2 - JFET, DCB1,D-Reflector, BibFet, Buffalo II,ES9018K2M, Arduino LDR Volume, AK4490 Discrete Mirand Audio,SSHV2, 6V6 Salas Preamp. USSA-5.
Old 25th September 2016, 12:35 PM   #706
Project16 is offline Project16  France
Project16's Avatar
Hello nikosokey
It is a pleasure to see that my route was served, the only small problem is that the four capacitors of this circuit are small beings.
Achieving your copper engraving is perfect!
Regard's
Old 25th September 2016, 12:45 PM   #707
nikosokey's Avatar
Many thanks Project16 for all...
BR Nikos
Old 25th September 2016, 12:48 PM   #708
nikosokey's Avatar
Hi Keantoken
I use ON Semi
I need to make changes for better results?
Old 25th September 2016, 01:19 PM   #709
Project16's Avatar
Originally Posted by nikosokey View Post
Hi Keantoken
I use ON Semi
I do not know if with Fairchild is better but I use CDIL and listening is very good.
Old 25th September 2016, 07:14 PM   #710
nikosokey's Avatar
Measures after trimming for dc offset=0.1mv-0.3mv +/-
Vbe Q4=672mv, Q2=670mv Q3=618mv Q1=615mv
on R2=56Ω=51.2mv
on R12=150Ω parallel to trim 100Ω=51.3mv
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 3rd January 2011 11:00 PM
error correction et al' sq225917 Digital Source 4 7th August 2007 10:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 04:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
