The Kuartlotron - keantoken's simple error-correction superbuffer
The Kuartlotron - keantoken's simple error-correction superbuffer Please consider donating to help us continue to serve you.
Old 13th August 2016, 08:55 PM   #661
Destroyer OS is online now Destroyer OS  United States
Destroyer OS's Avatar
Originally Posted by Theodosis O. View Post
and with SMD components.
I hope this is your sense of humor; that or you're going to send me a $3k hot air bed station....
Old 14th August 2016, 12:28 AM   #662
keantoken is offline keantoken  United States
keantoken's Avatar
SMD would be great, there are SMD versions of many discontinued TO92 parts. It comes with a learning curve and retooling cost though. I think in the interest of parts selection we will have to eventually. But for this circuit the important parts are still available.
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 18th August 2016, 08:05 PM   #663
BRN is offline BRN  United States
I wanted to know if the new board will only require a rectified bipolar power supply like the one pictured?
Also, if I us a 100K stepped attenuator on the input do I need the 100K resistor?
Old 19th August 2016, 01:03 AM   #664
jslot is offline jslot  Netherlands
how can I order boards to build a stereo preamp?
Old 19th August 2016, 03:27 AM   #665
Yes. There's no rectifiers on the board Keantoken just posted. A 9v x2 transformer will work nicely with the new regulated boards, otherwise it's a bit high and 7v would be better for the current boards that I'm using without regulators.
I would leave the 100k in, unless you want to see just how powerful your source is...
Old 27th August 2016, 01:13 AM   #666
I just got my boards today, thanks keantoken for the quick shipping.
They are nice and small. I do have a couple of questions before I start the build.
1. These boards required that I make the 15pF 270R connection off the board?
2. The boards do not indicate the transistor types. Are they installed in accordance with the attached picture?
I'm still waiting on a couple of parts. The RJM X-reg board, ebay DACT 100k stepped attenuation, input selector switch, and a chassis.
Old 27th August 2016, 09:00 AM   #667
Catal is offline Catal  Italy
Boards just received, thanks.
Now it's time to build it :-)
Old 27th August 2016, 09:13 AM   #668
keantoken's Avatar
Thanks for the picture BRN, that is correct. Mount the trimmers with the screw matching the print, except they will be facing the other direction.
Old 27th August 2016, 05:42 PM   #669
Yes.
Old 28th August 2016, 03:32 AM   #670
keantoken, Destroyer OS.,
Thanks for the information. Can't wait to put it together.
The Kuartlotron - keantoken's simple error-correction superbufferHide this!Advertise here!
New error correction amp PMA Solid State 101 4th January 2011 12:00 AM
error correction et al' sq225917 Digital Source 4 7th August 2007 11:16 AM
Visual error correction? Circlotron Everything Else 4 15th September 2003 05:17 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
