Hi John,
Computer problems now resolved, thanks.
Best wishes,
Susan.
jkeny said:Susan, sent you some emails but don't know if you are receiving due to your computer problems, so this is just a note to see that all is ok at your end?
Best wishes,
Susan.
"I don't think that that the Aikido preamp would be able to drive the 600 ohm load of a Zeus power amp stage with the 5687/6SN7/6AS7/etc. type tubes specified..."
Dear Susan,
Aikido preamp with 6SL7 at the front and 6SN7 at the end has voltage gain ~35 and output impedance ~800 ohm...
It seems to be perfect to drive Zeuses!
Output impedance isn't the same like load impedance.... But if you like distortion, so go on.... 😉
Upupa Epops said:Output impedance isn't the same like load impedance.... But if you like distortion, so go on.... 😉
So what should be output impedance of the preamp to easy drive 600ohm loads?
Easy drive 600 Ohm ? You can drive Zeus with this preamp, but question is, what is distortion of this amp in this case... I'm afraid that will be too high...
Upupa Epops said:Easy drive 600 Ohm ? You can drive Zeus with this preamp, but question is, what is distortion of this amp in this case... I'm afraid that will be too high...
agree,
but what output impedance pf the preamp would be enough?
anyway, no matter,
the best to drive Zeus from power output amplifier!😀
Is common rule, that output impedance should be minimal ten times lower, than load impedance... 😉
Susan,
As an amp builder neophyte, I've enjoyed the thread on this amp because of its unique approach. I'd like to try it, but with a different driver and have a few questions. First I'll explain my mad plan:
I've been building a speaker system that has four drivers per side and will be powered by four amps per side. From about 350 Hz down, I have two solid state amps (Symasym that were from Mike B. here). Above that range is a Unity Horn that has a compression tweeter for about 1100 Hz up, and four mids for the range between 1100 and 350 Hz. The tweeter and mids are about 105-110 dB efficient, so for modest listening levels, I'll have two stereo 801 amps (one built so far) based on a design from Steve Bench: http://members.aol.com/sbench/inp_dri.html, my version here: http://www.diyaudio.com/forums/showthread.php?s=&threadid=72361&highlight=. It does sound very nice, but since it only puts out about 0.5 watts into 8 ohms, it's obviously not going to be able to keep pace if I want to crank up the volume. Sooo..., as it was actually designed as a driver, I thought; why not build a separate output stage that can be added in when needed?
Your amp has many features that make it a good candidate. It has enough power for my needs. It's transformer coupled, which means I might get by without a tweeter protection cap. And, it might well retain the sound character of the driver stage. So my questions, should you be so inclined as to participate in this quixotic quest, are:
As I understand it, the Mosfet end of the circuit doesn't provide significant voltage gain. Since my amp power/voltage output is so low, I would need the input step-up transformer. I could just use what you show, but I could also bypass the opt's on the 801 amp and use about a 1.2k transformer instead of the current 12k. This would mean one less transformer in the signal path, which seem a good idea to me. Your thoughts?
If I do bypass the regular 801 opt, I have a couple of choices. The easiest would be to use the same cap coupled transformer output, just a different transformer. This should work without changing any of the operating points of the 801 amp. It is possible to bypass the resistor load and make a regular single-ended transformer coupled output. I'm leaning against this, because it would likely change the sound, and I'd have to adjust the bias voltage between the two systems. Assuming I get a separate transformer to assume the role of the Zuess input transformer, do I need the center tap for the mosfet bias supply, or can I make a resistor divider pseudo center tap?
With four stereo channels needed, size is an issue. I don't really need 75 watts, certainly not in any continuous fashion, though good peak output can't hurt. I think 15-30 would do nicely, and I don't need frequencies below 300 or so. Can I have smaller transformers wound? I didn't find the winding info on your site that I saw some time ago.
Thanks,
Sheldon
Thanks,
Sheldon
Sheldon said:[B I didn't find the winding info on your site that I saw some time ago.
[/B]
Found it: http://www.susan-parker.co.uk/zeus-out-tx.htm
Sheldon
Has anyone tried using the Lovoltech's in this design? They wouldn't deliver as much power, but they would require fewer components, and presumably work rather well.
actually, 0.5W into a 105dB/W/m driver ought to play louder than any sane person wants in a reasonable size living room...Sheldon said:The tweeter and mids are about 105-110 dB efficient, so for modest listening levels, I'll have two stereo 801 amps (one built so far) based on a design from Steve Bench: http://members.aol.com/sbench/inp_dri.html, my version here: http://www.diyaudio.com/forums/showthread.php?s=&threadid=72361&highlight=. It does sound very nice, but since it only puts out about 0.5 watts into 8 ohms, it's obviously not going to be able to keep pace if I want to crank up the volume.
snip...
10K:10KCT transfomers are fairly common, one of these (especially parafed) might make a good output stage for an 801 to direct drive the MOSFETs...
Peace
Hi suiraMB,
low rdson seems to be the criteria for this amp - how would they require fewer components though?
John
Roscoe Primrose said:actually, 0.5W into a 105dB/W/m driver ought to play louder than any sane person wants in a reasonable size living room...
Peace
For average volume, certainly. For transients, not so sure. However, the 105dB is not the full story. The horns are conical and so they fall off at 6dB/octave starting about 5 or 6k. So maybe more like 100dB in the end. Yes, they do sound nice at normal volumes and normal for me is nothing like ear splitting loud. But I'm intrigued by this design. Don't tell Susan, but I think I'm going to try a scaled down version with some smaller FET's to do about 10 watts or so.
Peace [/B]
Yes, I'll check it out. I'd like to be able to do a 2:1 step down. That would be pretty much the ideal match. Shouldn't be hard to find something on that order.
Sheldon
jkeny said:Low rdson seems to be the criteria for this amp - how would they require fewer components though?
The LU1014D have an Rds(on) of 0.007 Ohm, so they should fit that criteria very well.
They have a very low gate charge (~10nC), and ~1nF capacitance, which should allow for very good high frequency response and slew rate. In fact, parasitic capacitances in the secondary winding of the input transformer may very well swamp the JFET parasitics.
Finally, with regards to component requirements, they are depletion mode devices. You do not need a positive gate voltage to drive them. Also, being JFETs, they are less sensitive to static discharge and such, so you could simply connect a center tapped input transformer to the gates and the negative rail, for a grand total of 2 transformers and 2 semiconductors.
The simplest way to bias them, is to make sure the transformer primaries have a sufficiently high primary DC impedance; this is just like cathode biasing a valve. You need to develop this negative gate voltage, because they will give you 25 amps at 0Vgs with a 1V supply.
With a transconductance on the order of ~20S at low voltages and a triode-like curve, the potential for low distortion should be significant. You could even use a lower voltage power supply and a step up transformer. At 1:3, you would still have a more than sufficient damping factor.
suiraMB,
This sounds excellent - but I'm not a tubes guy - any chance of your take on a schematic?
I will try to order some jFets- although Europe group buy is finished through Steen. I will use toroid mains transformers to test - will these satisfy the high primary DC condition you mentioned?
As you can see I'm more questions than answers.
John
John
If I looked at the correct device, it appears that they are rated to 25V. This would only allow a max. 12V rail, as the FET sees twice the rail voltage, due to the neg. voltage developed by the transformer.
Sheldon
Sheldon
12V rail with sensitive speakers & no o/p transformer could work just fine. it would enable higher standing current which gives lower distortion ( at least, in simulation )
I had intended to run off 12V SLA battery anyway (PSRR of design is low or undetermined I think - so quality PS is necessary for quality performance).
I don't know what the power from this setup will be but SI T-amp is loud enough for me even with Rogers LS3/5A ineffecient speakers.
John
That's a completely different project.
Sheldon
- Zero Feedback Impedance Amplifiers
