Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
The gate voltage depends on the DAC. For example it is at 0V for PCM1704.
You have to judge for your own case, as I have not spent time on your DAC circuit in detail.
If you use an offet voltage you need to change the value of the resistors across caps to make sure they match with the offset.
See the ES9018 implementation (SEN Version 18).
Patrick
Could you post a link to the schematic for the cascoded balanced version that sounded so good?-- I tried to find it but the thread is long. Also are folks still preferring Joachim's PSU?. I noticed that the SEN is supposedly sensitive to PSU mains power supply noise hence the common mode choke, alternatively using a choke filter before a Salas.
Sent from my iPhone using Tapatalk
Cascode BF862 with LS832
Fair enough about batteries ... haven't read through but I assume you have a row of switches that go from recharge to supply?
The BF862 is indeed attractive because low noise and low cost/easily available. I recall reading that it is recommended to cascode this. Considering the LS832 as a dual low leakage/capacitance jfet for cascode? The U431 used in this article: http://http://www.ncbi.nlm.nih.gov/pmc/articles/PMC2872042/
Reasonable or better with J111, etc.?
We used matched J111's.
I've read the article as well as the discussion regarding the BF862 which is easily available. I also read where you were testing the coupling caps ... Obbligatos for example are not very expensive ... did you find a significant difference? Obviously some extra room on the PCB but if it is at all better then worth it. Do you do this type of cascode (?Borbely type)? I'm sure these are neophyte questions and this circuit may be totally off, but I'm trying to learn.
Am I on the right track?
  • sen-iv-cascode.pdf
