Cartesian or CoreXY refers to the kinetics; the math behind the gantry's movement.
In a bedslinger, a Cartesian machine, the Y movements are the result of bed movements.
In ordinary CNC, also a Cartesian machine, the Y movement are the result of the gantry moving along a second axle.
In a CoreXY machine there's no X or Y stepmotors, they are often named A and B.
Pros are for example a lighter gantry; no step motors for the Y direction.
Cons for example are that the belts are rather long, that's not suitable for larger machines.
In theory, a bedslinger machine can have CoreXY kinectics for the X direction and the bed slings for the Y direction.
A little help was needed to get the membrane in between the aluminium layers in the corrugator:
I still need some help in holding the membrane stretched though.
One width for the mid membrane and one for the tweeter:
thank ok the one i had in my head is the core XY then 🙂 they are interesting !Cartesian or CoreXY refers to the kinetics; the math behind the gantry's movement.
nice got a whole laminating line there ?
ah well still a form of laminating haha nice !! be it temporarily. great idea by the way using a second layer for baking. i remember this baking step only from the amts and back then it never worked for me but ,i clearly did something wrong !! looking forward to the resultsNo, it's for the corregator. The two 40µm aluminium layers upholds the corrugation while baking.
Final assembly:
Some EPDM sealing P-strips.
Alignment helpers:
Two SMAPPPs!
Alignment helpers:
Two SMAPPPs!
Nice!
What crossover frequency did you go with in the end, both on the low end and between the mid-planar and tweeter-planar?
The full length membrane measured the same at the short ones but SPL and distortion wise.
Sub to 120Hz @96dB/octave,
Bass 80Hz to 300Hz @96dB/octave,
Mid 300Hz to 3000Hz @ 96dB/octave,
Tweeter from 3000Hz @ 96dB/octave.
I need to raise the gain of the tweeter amplifiers so that I can compensate for the slope above 10kHz.
If I instead EQ all below 10kHz, the overall SPL will be too low.
- Planars & Exotics
- Yet another Planar Magnetic Line Source, the SMAPPP
