XXV Sampson power up issues
Example. Done through 2 ohm resistor. It took approximately 10 seconds of heating to get to the second photo.
I don't understand. Do this... resistance across the pads for both pairs of resistor pads and diode-check across both pairs of resistor pads in both directions (probe positions reversed). One resistance value for each pair of resistor pads. Two diode-check values for each pair of resistor pads. Post the EXACT value displayed on the meter, even if they are all zeros.
