Sorry about that. Here’s the link again
https://www.diyaudio.com/community/...ne-amplifier-dc-protection-modules-gb.349294/
You can buy the board here:
https://xrkaudio.etsy.com/listing/1100022087
Thank you for the kind words.
Good luck on your layout!
Dear Sir Xrk971.
Tell me, please, how can I replace the sq4282 component?
The price is not important, the main thing is that this component is sold in the store lcsc.com , and so that the replacement does not lead to a change in the scheme.
Thank you in advance.
Sincerely, Alexey.
Sincerely, Alexey.
I’m sorry, I don’t know what you are referring to? This is the PCA thread and I don’t recall a part called SQ4284?
Or are you talking about the headphone SSR? In the headphone SSR, SQ4284 is the main relay MOSFET. If you want to swap, look for a dual N channel MOSFET with SOIC-8 package and with low RDson around 15mOhm. They are in stock at Digikey for $1.50 ea.
LCSC doesn’t have a lot of parts. You may need to order those at Mouser or Digikey.
Thank you very much for your reply, Sir Xrk971.
I apologize for not specifying which project we are talking about. Yes, I'm talking about SSR. I don't understand the quality of the component.
Due to the sanctions, I cannot make purchases in these stores. Mouser, Digikey.
I didn’t realize you were in Kazakhstan. All I can say is search the web for places that may sell SOIC8 dual N channel MOSFETs. Look for keywords “Trenchfet” “Automotive”.
Have you tried Aliexpress? I tried searching for SOIC8 dial N channel MOSFET and got a lot of hits.
This might work:
AO4818B SOIC-8 Dual N-Channel 30V / 8A patch MOSFET (FET)
https://a.aliexpress.com/_mqky5NS
Or this:
FDS8949 SOIC-8 Dual FET, MOSFET, double N channel, 6A, 40V
https://a.aliexpress.com/_mrXuQwY
Hope that helps.
This might work:
Or this:
Hope that helps.
Yes, perfect! The RDson is just a tad higher at 24mOhm but suitable for a SSR. Can handle 40v too so that’s even better. As you can see specs are very similar and with same pins.
If you want to continue discussing the headphone SSR I would suggest moving discussion to that thread.
See if post #2179 helps you.
https://www.diyaudio.com/community/...ass-a-headamp-gb.302859/page-109#post-7315210
This works too:
Just found this amazing item on AliExpress. Check it out! $1.91 5% Off | 5pcs RK097GS 8PIN 10K 50K 100K B10K B50K B100K RK097G with a switch audio shaft 15mm amplifier sealing potentiometer
https://a.aliexpress.com/_mrGdpGQ
https://www.lcsc.com/mobile/product...iometers_ALPSALPINE-RK0971221Z05_C336003.html
I ordered these. They are the real deal.
hello
am having real trouble sourcing the 390 uF 20V capacitors for C2_1. does anyone know where i can find these? i've looked online a bit and only found them at mouser, who want around 20.- to send them (i'm in switzerland). tayda doesn't stock these. seems like a non-standard value.
many thanks for any help!
thank you!Try 1000uF 16v SEPF. In any case, the amp will sound quite good with regular high quality caps from major brands like Nichicon, Panasonic, Elna, etc. try it with what’s available. The difference is marginal and only in the bass authority.
- Group Buys
- xrk971 Pocket Class A Headamp GB
