WTB: F4 PCB boards
jrebman said:
So Peter, do yu recommend another new thread be started for a second group buy, or what's the best way to go about this? Would this include just amp boards or PSU as well?
Any rough idea on what parts cost for a finished F4 runs?
You can post here or start a WIKI page. PS boards will be also available.
The parts for two channels shouldn't cost you more than $100, plus transformer and chassis.
Peter,
Thanks, this is looking really interesting. I'm already about 10% through the F4 thread and this looks like it will be a great amp -- bridged monoblock, or basic stereo to drive my Sapphire XLs.
Is there a parts list somewhere? I am asking because I'm blind and can't see the schematic to be able to make my own.
Is there provision on the PSU board for a CLC filter? Any guesses as to what the size of a finished amp would be?
I appreciate your patience as I come up to speed on all this, but I've always thought a unity gain buffer was really the way to go, but this one with no global NFB looks even that more interesting.
Thanks again,
Jim
The schematic can be found here: http://www.firstwatt.com/downloads/f4_om.pdf
The parts list is attached. As the boards are based on original amp design, no CLC filtering option on PS board. Another reson is that I wanted to keep the size down, you can always attach inductors off the board.
Some parts were also listed here: http://www.diyaudio.com/forums/showthread.php?postid=1329905#post1329905
The finished amp size will depend on your chassis, heatsink need to be of reasonable size though. An example is my F3 monoblocks where I wanted to keep the size to minimum, yet still came out with 11 x 11 x 11" (stereo amp would be same size)
http://www.diyaudio.com/forums/showthread.php?postid=1254948#post1254948
  • f4-parts.pdf
JoshK said:
I agree and I like the fact that I can provide, for example, a tube gain stage and use the F4 for current amplification only. This seems the most logical way to pair tubes and SS.
Now that you mention it, a tube pre might be something I would experiment with--I've always been fearful of high-voltage. Does a tube preamp use lower voltage, or at least, safer voltages?:)
