WTB: F4 PCB boards
Now I have shortened my layout down to 250x100mm. Distance between mounting holes on output transistors have decreased from 5 cm to 4 cm.
I have uploaded the current layout so you can see how it looks.
The silk screen has not been cleaned up, but I'll do that before the layout goes to print. Mounting holes, drill sizes and absolute placement of the two channels also needs to be sorted.
I'm open to suggestions and tweaks.
It might be a good idea to call them "sets" and not "boards" in order to avoid confusion... 😉
The pdf I have posted contains both left and right side. The board is supposed to be split in left and right board between the fat output traces. And then you have one "set".
Jason invited me to post here a layout I completed last night. The board size is 2.4 x 3.35" . I had enough space to add two optional bypass caps.
They will be beautiful blue, like in attachment. As to Dales, they will only fit in vertical position. I may consider going with full size resistors, but somehow those miniature resistors seem to fit here very well. And I was designing the board with a thought of using Caddocks or Vishays, that's why such small footprint.
