wiring tubes in series
how do i work it out?
The anode current is on the data sheet:
http://www.mif.pg.gda.pl/homepages/frank/sheets/106/1/12DU7.pdf
Look at typical operating conditions on the data sheet.
Plate means anode..
ie plate current is 12mA..so put the largest value in you can in and have it work.
Then measure the voltage across the resistor. Divide the voltage across the resistor by the resistor value that gives you the current. You can compare this to the 12mA and drop the value of resistor until you get 12mA
Its not much current.
M. Gregg
ok so i am left with 0.006A or 0.006mA
The current through the resistor is the current through the Tube and also the current through the Output transformer
ie the current is in a circuit from supply through the output transformer then the tube then the resistor. So measure the cathode resistor and your measuring the value of the tube current which is anode current,,
😀 I'll give you a clue .5 A is 500mA..
M. Gregg
ok thanks, should i simply put 2 330ohm resistors in series to get me 12mA current? thanks
Aran
If you reduce the resistance you increase the current.
If you increase the resistance you reduce the current.
Resistors in series is increasing resistance,
If .1A is 100mA what is .006A?
If .01A is 10mA..
Its just a bit of fun..😀
M. Gregg
