Wire From Ext. Crossover to Speaker
Jeff, in your cable idea for high-pass (2x23Ag, and 2x18Cu) which cables do you connect at the ends? do you keep the Ag together for + and CU together for - or mix 1 of each au/cu for each leg?
I'm thinking of doing an external box for my ellis 1801 and wire direct from the xover all the way up to the drivers.
My apologies for the very late reply. I was out of town from the 15th thru the 19th. I was too busy to check the forums 🙁 I have not spent a lot of time here since we started a forum at AC.
I connect them one each for each polarity. As you said, "mix 1 of each au/cu for each leg".
