I have the parts together for a quick and dirty 2 way open baffle system. One of the uses I have for them would be as studio monitors and the desk has the center of the 12" bass driver basically at ear level. I would be using a DSP amp so I can mess with delay and other parameters.... but I was thinking about mounting the full range driver coaxially. I don't think I've seen such a setup here outside of pre-made coaxial drivers.... am I missing something?
Most pro brands offer coaxials. Some executed quite well. Some bass, mid and high. It’s really not that special.
Me-Gethain comes to mind.
An example of what they produce:
https://www.me-geithain.de/en/rl-801k-11.html
For me it's because of the relatively crappy responses produced by many of the "tweeter" sections in coaxial drivers. Also because IMO the purported advantages of a speaker with coincident sources are over-hyped and not really necessary.
No, not missing. As mentioned there really isn't an advantage other than space saving so if you don't have to, then don't. It's kinda tough to hang your full range in front of the woofer without having some awful interference between the drivers.am I missing something?
They can sound really nice if done well. But I do prefer a normal woofer and big horn. This summer I will be resurrecting John Busch's 18" coax on OB. They do live up to the hype (if I can get the crossover right.) Stay tuned.Also because IMO the purported advantages of a speaker with coincident sources are over-hyped and not really necessary.
FWIW, a proper (separate) tweeter and woofer have a higher potential for sound quality. Like I said there is no need for coaxial designs. I think this is a relic of a former time when tweeters either did not exist or could only work above about 3k-4k Hz. Now a good CD+horn can be crossed over near 1kHz for home audio use. Even good dome tweeters can be crossed at 1.5kHz.
I say go for it... It is a very reasonable idea, especially for near field listening. Are you going to be using the DSP as an active crossover? If so, it will be easier to find an appropriate crossover frequency.
It's easy to assume coax is about lining up the sources with your ears, but that's not normally the issue. A one in front of the other arrangement can have the same issues as a conventional one above the other arrangement, as they can both produce lobing which distributes sound around the room inconsistently.
I was just looking at 12" coaxials. Parts Express has lots of them. They are apparently used for stage monitors where compact size is desired. I read good things about the Eminence units.
https://www.parts-express.com/speak...-horn-drivers/pro-coaxial-full-range-speakers
I couldn't disagree less.Also because IMO the purported advantages of a speaker with coincident sources are over-hyped and not really necessary.
Coaxial need not mean Tannoy like, but MEH, and I've never heard anything better yet when implemented well.
That doesn't prove anything.I've never heard anything better yet when implemented well.
Neither does any opinion you offer.That doesn't prove anything.
If I read correctly, the OP has woofers and FR units on hand so I’m not sure why some are suggesting he go buy a pre-made unit or commenting on the different qualities. What he wants to know is can he place an open backed FR unit in front of a woofer. The answer is yes. Is it a good idea? Absolutely not. Build it as you would with a normal two way.
Good luck with it.
Good luck with it.
KEF Q350 (460 Euro a pair here in Germany/Amazon , in white colour with silver cone very nice) , needs some extra polyester damping inside to suppress standing waves and at least 1 layer of self-adhesive bitumen damping pads 4mm thick on both side walls (inside the box) :
https://www.audiosciencereview.com/forum/index.php?threads/kef-q350-speaker-review.13484/
Comes with a foam plug to tame port noise and damps the boomy upper bass range (typical problem of most speakers) but the lower bass will be affected too .
In my room 6x5m the Q350 are placed near the longest wall with 5cm distance to the wall and the lower range is way too much boosted by the wall (acoustic loading) .
But I can compensate that using the sound controls of my Yamaha AS701 amplifier (650 Euro/Amazon) easily .....
I am very happy with this combination/setup! (typical listening distance 2m)
https://m.media-amazon.com/images/I/71OVU7Lx+iL._AC_SX679_.jpg
No everyone Weldon, not everyone.I’m not sure why everyone is suggesting
- Why don't people build more coaxial systems?
