Why aren't there PAPER dome tweeters?
A one inch voice coil is a one inch voice coil, most of the old cone tweeters I've opened up have used much smaller diametres, 12mm to 20mm. A70mm cone with a 32mm voice coil would definitely be interesting but wouldn't the high mass of the big VC raise issues?
A textile material has a more open weave than paper, and it is into the openings in the weave that the stiffening substance permeates.
The result is a combination of lightness and stiffness that likely cannot be achieved with paper and an external coating.
Not external coating but impregnation, which is internal.
There is free space between paper fibers.
There are a few of those around which can come in quite handy for vintage loudspeaker renovations.
For example: https://www.monacor.com/products/components/speaker-technology/hi-fi-tweeters-/ht-22-8/
And: https://www.visaton.de/en/products/drivers-accessories/cone-tweeters
Here's a recent discussion on cone tweeters: https://www.diyaudio.com/community/threads/why-arent-there-any-great-cone-tweeters.393952/
Thanks, I too discovered that article after making my initial post.
Still so useful that I made a batch of high power paper cone tweeters, go figure.
They reach way lower than any dome, greatly simplifying cabinet design , sound way louder than any dome and are more directional, which in a live Musical Instrument or PA is a bonus.
@JMFahey are you using any wadding or absorbing material between the paper cone and the sheet metal of the closed back tweeter?
I've always been impressed by the little Coral 50mm tweeter that had an open back and a small plastic cup filled with polyester, but it only had a 12mm voice coil; I wonder what it would have been like with a proper sized VC to handle more than 20 watts peak. I have a whole stack of small full range drivers but not really impressed with them as tweeters and my hearing above 15k isn't much good anymore
Why i invariably add a laye rof puzzlekoat/ModPodge to bind them all together so they can’t rub together an casue cone self-noise.
Loudspeaker cone self-noise?
Now that's a concept which is currently evading my legendary googlin' skills!
I do read that the addition of synthetic fibrillating fibres with their tree-like structure to the paper pulp can mechanically bind the paper fibres together so they won't rub together.
Images of fibrillating fibres:
Reactions: JMFahey
Not really but gluing some felt to inside of bell would certainly help flatness.
Not too worried about in MI cabinets where the 3 most important parameters are Loud, Louder and Loudest 😄
Reactions: head_unit
Well, one of paper pulp components is some kind of glue.
As usual, all sauces are secret, cone makers don't divulge them even under torture.
Reactions: freddi
